Question about Car Audio & Video
Factory wiring harness in a Tras Am
In my 95 model Trans Am there are two different wiring harness one for the radio and I was wondering what the other one might be used for?
  • 2,039 Answers
Some came with amp in cars they put different option they install the wire that y cheers
Posted on Jan 14, 2008
I have brought a second hand unit and was wondering if I can order the wiring harness from anywhere or make one???
So you purchased another radio, right? Then it came with the harness already(for the radio and not the car). If the current radio is the factory radio then you need to purchase a wiring harness for the model/year of your car that will be compatible with your car's harness. Wal mart carries some but if you can't find it there then you need to go to your local car audio installation shop and buy one from them(it might be pricey there). Now, if your current radio is aftermarket, look to see if it already has the wire harness in the back. If it does then your good to go, just cut the harness from the radio away from the harness that plugs to the car's wire harness and reconnect using your new radio's harness(just follow the wire's color code). but if it doesn't then you need to buy one.
Jul 06, 2011 | Car Audio & Video
I am looking to remove my factory radio in my 2003 Ram 1500 and was wondering if I can get a diagram and instruction on how to do it.
here you go
take factory trim of from around radio should just pull off with a little force snap clips hold in pannel .
then once pannel is off then remove hex head bolts then pull out radio and remove wire harness from back of radio and antenna
to install aftermarket radio you dash kit radio and wire harness and antenna adapter ....
http://www.tintingbyfredjohnson.com
Dec 27, 2010 | Car Audio & Video
Need to replace tcc silonoid on a 95 beretta 3.1 v6 where is it located?
the tcc solenoid is located in the tras! when u open the hood on the drivers side ! look at the trans it will be the plug thats on the bell housing ! the plug could be white or blue! the trans must be removed to replace!
May 04, 2010 | 1995 Chevrolet Beretta
It seems like there is alot of wiring in the back of my factory cd/cassette/am/fm radio. i am thinking about replacing the radio with an aftermarket one and i was wondering if there are any problems that i...
You can buy aftermarket plugs that will plug in to your harness and have the radio wires on the new plug. This keeps you from cutting your harness and reinstalling your factory , if you decide to.
Jan 06, 2010 | 1995 Volvo 960
Canabalized wiring job on OEM radio
You should buy a replacement harness to restore the OEM wiring, so that you can then properly plug it into an aftermarket harness that has been mated to your Kenwood radio's harness. The next buyer will appreciate that the factory radio has been replaced when you're done with the car, and you get the added benefit of not being forced to leave your Kenwood head unit in it, since it can be easily unplugged once you're at that point.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jun 22, 2017 | OEM Systems Car Audio & Video
The stereo wire colors for the 2001 chevy s 10
Radio 12v  orange  +  radio harness Radio Ground  black  -  radio harness Radio Ignition  dk. green  +  radio harness Radio Illumination  brown  +  radio harness Factory Amp Turn-on  orange  +  radio harness Notes: The amplifier is behind the glove box. Power Antenna  N/A     LF Speaker +/-  tan - gray  +,-  radio harness RF Speaker +/-  lt. green - dk. green  +,-  radio harness LR Speaker +/-  brown - yellow  +,-  radio harness RR Speaker +/-  dk. blue - lt. blue  +,-  radio harness
May 02, 2009 | 2002 Chevrolet S-10
I just put a transmission from a 1994 chevy 1500 onto my 1993 chevy 1500. it fit perfectly but the wiring harness is different. is there an adapter for this application? if so, and i install it will i need...
what color is the inside of the trans connector on the trans itself? I believe the 93/94s were a tan yellowish color. 1995 and up are different and won't work - electronics are different
If they have exactly the same amount of solenoids, you could switch the harnesses.... but it sounds like you have a 95 or newer trans which would have one more solenoid
Apr 11, 2009 | 1993 Chevrolet C1500
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
New Car Radio, New Harness but no power, Nissan P/U '95
here is the factory harness wires and what they do, recheck thayt it all matches up.
1995 Nissan Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Mar 10, 2009 | 1995 Nissan Pickup
Car Audio & Video Logo
124 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
