Question about Sony PlayStation® 3 (60 GB) Console
Ps3 av-muti problems
My ps3 has line going up when i turn on the system. I think something is wrong with the av-muti in the system. Because I have change the av-muti cable and it still does it. Is there anything I can do
  • Evilishkink Feb 14, 2008
    My av-multi out does not display any thing on my t.v i tried the reset for 10sec thing and i don't know if i need a new wire or it's broken. I just want to know if it's the wire or it's the slot in the ps3 that's damage. HELP!!!
  • ronniePetitt Jun 30, 2008
    I played switched my ps3 from a regular to hd tv and it worked now that I switched it back it no longer will show picture or sound. What can I do?
    Genius:
  • 1,019 Answers
the PS3s are a relatively new console.
My suggestion would be to find out your warranty, and return for repair or replacement.
Mike @ Compurepair.
Posted on Feb 22, 2008
My game keeps getting horizontal lines of distortion. I think its pecause of my ps3 or tv settings. How do I stop this?
Actually, it may be your laser/lens.
ry accessing the recovery menu 'safe mode' 1st.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
If you have a HDMI cable, plug it up, if you have AV plug it in as well. If you have both settings on your TV, be sure to have them both inserted into the system. Also, make sure that you are switching your TV from HDMI to AV and vice versa.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 2-5.
If you still are getting the horizontal lines, chanes are it's your laser/lens.
This is the 2nd most common problem with PS3's. This isn't a bad problem. Your laser/lens will need to be replaced. There are many videos on youtube if you would like to do it yourself (I would advise you not to). I recommend that you find a technician who has experience. There are many things that can go wrong.
Jan 24, 2011 | Sony White Knight Chronicles:...
I bought pioneer muti system dvd
Check your DVD player's color system, most multi system dvd player has to be set(PAL or NTSC) manually, NTSC for American standard. Look for this button could be a mechanical switch at the back or at the menu. Some machine need to reboot after setting. Hope this helps
Mar 04, 2010 | Samsung DVD-V90K Multisystem DVD/VCR
Wont show anything
Try to restore your ps3 system in the recovery menu.
Here is how.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Hope this will help you.
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
PS3 doesn't work with tv anymore
did you move the ps3 while it was on. If you did the reset for AV should repair both the AV problem and your HDMI as well. Shoot me a message back if it works or doesn't.
Thx
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
I used an optical cable from my ps3 to my receiver but no sound
change the sound output to 'optical' on your ps3
system menu
Sound
Sound output
(select optical)
I think you may have to change the channel on your AV reciever to Input or audio or something
Jul 08, 2009 | Audio Players & Recorders
Pic
if you have a SD TV. ( standard display, not HD ) but chose the HD display option on system settings you wont see picture but hear sound. and same goes if you've chosen SD display but own a HD TV. so try to reset your system somehow or take it in for inspection.
Jul 13, 2008 | Sony Playstation 3 (PS3) Console
No picture on tv screen.
Had the same problem. When I turned on the console, the screen went a bit fuzzy at first and then remained blank. There was no sound either, but I could still turn it off with the controller. I checked all the connections and even plugged it into another T.V. I have now discovered the problem! The scart connector which came with the PS3 wasn't working properly. Didn't have the prob before because I wasn't using it. Hope that this helps. If not, try holding the power button down for a few seconds after turning on the system. You'll hear a beep noise and the system will try to adjust its AV output or something. Worth a try anyway.
Dec 03, 2007 | Sony Playstation 3 (PS3) Console
Ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
I can't get the picture.
well make sure that the av cable is in tight in the back of the console and if it is wiggle to see if u can get a picture or somthin
Aug 03, 2007 | Sony Playstation 3 (PS3) Console
Picture won't show up.
Sony PlayStation® 3 (60 GB) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
