Outlet - unplug the power cable and put it on an outlet on its own
Power Cord - make sure you remove the power cable from the back and plug it back in to make sure you have a good connection.
things that cause this blinking light:
Power Supply -open system and follow cables to make sure its connected well to each part.
I/O Panel - this is where the power button is at . just open the system and follow it behind the power button.the flat cable going to the mother board , disconnect it. plug the power cable to the wall and if the system starts up then the power supply is good and the the cable that you just disconnected is bad.
If it still doesn't power up remove
memory
hard drive
dvd/cd drive
and start the system.
no luck then it is the systemboard.
