Question about GE WSXH208A Front Load Washer
Washer Start/Pause button is Falshing and won't start
The Washer won't start and door won't lock.
from Kentucky
  • carrieberrri Jul 15, 2008
    I have the same problem- my start.pause buttom only flashes and will not start unless I unplug it and plug it back in, then it will wash a regular cycle, door locks and everything like normal but I have to do this everytime I want to wash. Any suggestions?
  • 1,294 Answers
Try some WD40 on the door lock. The washer won't start if the door doesn't lock.
Posted on Feb 12, 2008
Light Blinking (start/pause)
Door lock faulty probably,,,,try closing door,,switching on and lightly thumping door near handle
Jun 15, 2013 | Tricity Bendix AW1000W Front Load Washer
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Wfw9150 door won't unlock
Try pressing the "end of cycle" button on the right side of the panel for 3 to five seconds. Wait for 3 minutes to open the door, do not force it. And you start all over again. Please reply as to the outcome. And if it is good you give me a 4 thumbs up rating.
Mar 14, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start
Sounds like the door lock may be faulty or it isn't closed fully. If it has a child lock check you haven't set it by mistake, you have to hold the start for 5 secs+ to override it.
Mar 07, 2013 | Bosch Axxis WFL 2060 Front Load Washer
The start / pause button will not work ...all other buttons are working
Make sure that the front door is locked or that the door switch is contacting to give the feedback signal to the main circuit board. This is a safety feature of the washer because unless the front switch works - door shut-the washer will not work - no action on start/pause.
Replace if the switch is faulty.
Feb 07, 2011 | Zanussi FLE1416W Front Load Washer
GE WCVH6800 Pressing start results in two short beeps. The pause/start button keeps blinking and it will not start a cycle.
Is the door lock button on, but the door not actually locked? Our door lock switch keeps going out. We have replaced it 4 times in the last 3 years.
Jan 16, 2011 | GE WSXH208A Front Load Washer
Door won/t lock to start washer
by pushing all the buttons the door finally locked and the washer started, thanks anyway.
Sep 29, 2009 | GE Dishwashers
Push start different sound water may start may not start pause
I would check to make sure the connectors to that door lock are all connected. If they are it's probably the lock/switch mechanism itself. Wow I just checked and they are about $120. The p/n is wh10x10006 You can google around for the best price. Good luck!
Mar 04, 2009 | General Electric WHDVH660H Front Load...
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE WSXH208A Front Load Washer Logo
209 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
