Question about Roper RAS6233KQ Top Load Washer
Roper won't spin
I have a Roper washer that is about 7 yrs old. It won't spin out . It will spin empty but you can reach in and stop it with your hand. Also if you have only a few pieces of laundry you can start the spin with your hand if you are lucky. I've looked at the clutch when its spinning and its spinning,even when you stop the drum. The shaft seemed to want to move during the spin but then stopped. So what do ya think? Thanks
  • Anonymous Feb 11, 2008
    will not spin at high speed
  • rednran Feb 18, 2008
    No I found that two of the bolts that hold up the transmission were snapped. We replaced tham and its working great. Alot cheaper than a clutch.
    Sniper:
  • 65 Answers
You need to replace the clutch assembly. requires special tub wrench. and some experience
Posted on Feb 18, 2008
Washer won't empty or spin
More than likely its your lid switch or your pump is clogged.
Sep 25, 2011 | Roper RAX7244KQ Top Load Washer
Good evening, My Roper washer RAX4232PQ0 will not spin...it seems to drain OK but won't spin...can you offer any help? Thanks!
I am thinking if all works good except won't spin, it is your lid switch. Under your washer lid you will notice a peg of some sort that when lidnis closed goes into a slot/hole and that triggers the spin cycle. That is in lamens terms know as a safety idiot switch. It is designed so when the washer is spinning at those high speeds,na child or not to smart adult does not open lid and put hand in while spinning. SO, if switch goes out, of course it won't spin. Switch is cheap , under 20 bucks at any appliance parts store, and they even can tell you at store how to putnin yourself by showing on one of there washers on display. Let me know if I nailed it!! Thanks Mike
Jun 09, 2011 | Roper RAX4233PQ Top Load Washer
Washing machine works up to the spin cycle, it does not spin it does however empty the water. this is a roper brand top load machine about 5 yrs old.
Lid switch. A safety mechanism used to make sure lid is closed in spin cycle. You can bypass this switch by placing the wires that go to switch together. DO NOT do this if you have children or do not want to remove that safety feature some require because they dont know better than to open a washer in spin cycle. :)
Jul 07, 2010 | Roper RAS8445KQ Top Load Washer
Roper Washer Wont Spin Out
Probably a bad lid switch. Open the control panel. Disconnect the lid switch wire connector on top of the cabinet under the control panel. Make a small insulated jumper wire and insert it into the wire that is still connected to the control panel. Set the timer to spin. If it spins replace the lid switch in the cabinet. If not, replace the timer.
May 05, 2009 | Roper RAS8445KQ Top Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Washer stops after wash cycle. Won't empty water, won't spin.
the lid switch is defective or the lid or door screws on left & right side are loose tighten and or replace. nbcrca:)
Apr 11, 2009 | Roper RAS8244KQ Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Roper RAS6233KQ Top Load Washer Logo
129 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
