Question about Nokia N70 Cellular Phone
Freezes up, won't shut off, doesn't reboot properly when removing battery
This phone never worked again after the battery died. It seems like it's stuck in some mode where it's lost it's mind. Even without sim card installed it doesn't boot properly.
  • HarleyTim Jan 13, 2008
    This is a Nokia 5300.
  • 36 Answers
The firmware for your phone might be corrupted. the only way to resolve this is to visit the nearest Nokia Service Center to upgrade the firmware. They might need your warranty card or something. Just bring it with you.
Please Rate Thanks
Posted on Jan 14, 2008
Phone "freezes up".
You may have a handset that has a small size onboard memory. Try deleting some of the non-important applications. Then buy an SD card..assuming your handset has an SD card slot. Reinstall the deleted Apps again and save it ti the SD card instead of the phone memory.
HOo to settings - Applications - Scroll through and delete applications that you have installed. DO NOT DELETE ANY SYSTEM FILES.
WORST CASE SCENARIO is to do a factory reset. Make sure the battery is fully charged.Go to settings - Security - Factory reset. The phone will shut down and reset to factory settings. When phone reboot, all installed Apps will be deleted and the phone will only have the Apps that it had or should have at the time of purchase. You will then be able to insert your SD card and install additional Apps to the SD card.
Hope this helps.
Dec 29, 2017 | Samsung Cell Phones
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
My Sony Laptop is stuck, not reboot nor shutdown,
Hey there, when your computer completely freezes while still being on you simply have to remove the power cable and pull out the battery. Then put the battery and/or power cable back in. When you start up your computer again it will say your computer wasn't shut down properly, simply select "start windows normally" and everything should be fine again.
Jul 27, 2011 | Computers & Internet
When i receive a message, my e73 doesn't make any noise. i've taken out the battery several times, turned it off and on, let the battery die, but it's not working. the only thing that indicates...
for it to ring delete all your messages from your inbox and outbox then reboot your phone (turn it off then back off) hope it works for you it did for me:)
Jun 21, 2011 | Nokia E73 Mode Cell Phone
My nokia5130 phone is not giving proper backup
do a full reboot roshanadhika
to do a full reboot, please follow this steps
1. remove the sim and the battery whilst the phone is turned on
2. insert the battery without the sim card then turn the phone on.
3. remove the battery again while the phone is on.
4. insert the sim and the battery then turn the phone on.
hopefully this works roshanadhika!
Nov 28, 2010 | Nokia 5130 Cellular Phone
My streetpilot c330 won"t shut off.
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Motorola Z3 died on me today. Can't start it at all. Help
the phone's need to be check the firmwares need to reflash
Jun 06, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Anyone help with this problem...
Some startup programs block process...Remove some programs and let me know if it works
Mar 31, 2008 | Acer Aspire 3000 Notebook
Nokia N70 Cellular Phone Logo
46 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
