Question about GE Profile J2S968 Dual Fuel (Electric and Gas) Kitchen Range
Preheating When I set the oven to bake and preheat it (to any temperature) the oven beeps after about 15 minutes, and the display reads the temperature I set it at.  However, it does not appear to be the same temperature inside the oven.  I have tried a number of times to bake something at the temp. that the oven displays, and it takes much much longer or the food doesn't get cooked all the way through.  We bought a thermometer to evaluate the "true" temperature inside the oven.  The temp. that the oven reads (what I set it at) and the thermometer we bought inside the oven vary greatly.  It will take up to 45 minutes for the temperature in the oven to display the temperature that I set the oven at.  What do we do?
  • GE Master
  • 43,501 Answers
If your electricPreheating - 2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 30, 2010
What does it mean when your Samsung flat top oven and broiler will not work and the code reads E-08
E08 Error Message on a Samsung Electric Built-in Oven:
The E08 preheating error code appears if the set oven temperature is not reached within 50 minutes. If this code appears, the reason might be due to overheated thermostats, a defective heater or a defective relay; in which case a repair will need to be arranged.
However, if food has been put into the oven during the preheating time that may cause the error code, since the presence of food cools the oven and so it doesn't reach the right temperature. The error message can be removed by turning the oven off and turning it on again.
To prevent this error code from happening again, the oven should not be used during the preheating period. The preheating period ends just after the sound signal and the icon in the display have turned off. When the oven gives the signal, it's close to the set temperature and your food can be put in.
Apr 14, 2015 | Samsung Kitchen Ranges
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
Ran the self cleaning cycle and now the preheat light will not turn off when it gets to the temperature I set it to. It just keeps preheating. Example: I set the oven for 375. It seemed like it had been...
Sounds like a circuit board issue. If in Warranty, contact the manufacturer and have the controller replaced. A routine cleaning has noting to do with the normal operation of the baking or broiling function. Cleaning is disengaged after the door is unlocked and ready for general aplications.
Feb 20, 2014 | Ovens
I need to learn how to use my oven, because i don't know how to turn it on.i need to bake,so can u tell me how?
You can get the manual for the RGB745 at the GE Appliances support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box. There are several models that start with RGB745.
On most of the Hotpoint ovens for regular baking, press Bake and use the + or - buttons to set the desired oven temperature. Then press Start/On. Then the oven will display Pre as it re-heats. When the thermostat indicates the desired temperature is reached, the oven will beep. The racks should be on the middle positions for most baking. (For roasting use the lowest positions.) Put the food in when the oven is done preheating. When done, press Clear/Off. Timed baked requires the clock be set correctly, then set the start and end times.
For the older ovens with dials to control the oven, set the first dial to Bake and the second to the desired temperature. Wait at least 10 minutes for the oven to preheat. Again put the oven racks in the middle of the oven for most baking.
Do not lock the oven latch and keep the oven closed through the baking cycle as much as possible. (Rotating pans and basting steps should be done quickly so that the oven doesn't cool much.)
I hope this helps.
Feb 11, 2011 | Hotpoint RGB745 Gas Kitchen Range
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
I have a whirlpool range. During preheating the
sounds like you may have a bad bake element. try to see if the unit will get hot when set to broil. if it does then try the bake again. if you get no red hot heat from the bake element then you may need to replace it.
when an element is working properly it will heat to a red hot glow.
Jan 12, 2010 | Ovens
Stoves 900DFa oven overcooking food
Sounds like the temperature control is bad. If it's digital you'll probably have to replace the circuit board. if it's a control knob, it's the mechanism behind the knob.
Jul 02, 2017 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
May 12, 2008 | Ovens
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
GE Profile J2S968 Dual Fuel (Electric and Gas) Kitchen Range Logo
729 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
