Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Wd63 does it have a filter to empty for the dryer!?!
I need some advice from someone who knows there stuff!! ive recently moved into a house that has a washer dryer and on inspection i can not see a filter to remove that you can take the fluff off? im not sure if im looking in the wrong place or it simply doesnt have one!!
please help me this is a severe blond moment!!
thanks
sarah
  • evans048 Jan 13, 2008
    thanks very much for your help i will no longer be worrying that its going to catch fire! so do i not need to remove any fluff from anywhere??
  • 139 Answers
Hi there sarah
The hotpoint washer dyrer does not have a filter for fluff
100%
Need any other help dont hesitate to ask
Posted on Jan 13, 2008
6ya staff
SOURCE:
Miss
The rebuilder may have move the jet needle position clip. Take the top off the carb and pull out the slide. Remove the needle and then move the clip to position 5 from the top. Try it noe. What you did was to provide a richer mid-range fuel mix. Hope this helps.
Apr 06, 2009 | 2005 Suzuki RM-Z 250
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
No power??
It's more than likely its the door lock, if not check the timer contacts on the top front connection block, if they have blown it will need a timer & door lock
Nov 02, 2008 | Hotpoint Aquarius WD63 Front Load...
WD63 washer dryer
your inlet valve is not opening properly and needs to be replaced. this is quite a common fault with inlet valves
Mar 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryer not wrking - letting in water
Does the water come in all the time? If so turn off each supply line faucet to identify which line is leaking and take that valve inside the washer apart and clean it out, if not completely replace that module. Let me know more about what exactly is going on.
Jan 17, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryer keeps stopping
Plugged filter or exhaust hose to outside could be clogged...Have someone turn the unit on and go out to see how much air is coming out of the vent. Should be a bunch. I'm guessing you have a blockage somewhere causing the unit to shut down and not catch on fire.
Jan 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Not Filling with water
Suggest you have a look at where your drain hose is going. The highest point in the hose needs to be higher than the "minimum drainage hose height" line marked on the back of the machine. Washing machines don't have valves to keep the water in - they simply rely on the pump pushing water over the hump in the hose when you want to empty them, and the water not being able to climb the hill on its own the rest of the time. A.
Apr 17, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
193 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
