Question about Teac A-H500 Amplifier
TEAC A-h500 integrated stereo amplifier
No sound from the amp - the power standby indicator is blinking. I have unplugged all wires from the back, turned off and on, but still light is blinking. I have replaced all wires and turned oof and on, but still no change.
trouble shooting guide says this happens if the speaker connection wires have short circuted or the output is overloaded.
  • 104 Answers
You have a defective power output, you have to replace it.
Posted on Jan 21, 2008
Why does my Teac ag h500 keep saying protect?
Hi. Unfortunately the protection circuit is saving your speakers from a fault, most likely one side of the amplifier in the unit is defective.
This needs an engineer.
Service manual is here if you need it. TEAC AG H500 Manual AM FM Stereo Receiver HiFi Engine
Oct 02, 2016 | Teac Audio Players & Recorders
Why won't it power on .it just stays in standby mode .
Top 10 Mistakes When Hooking Up a Home Theater System
www.audiogurus.com > Learn: Home > Cables
You don't have to buy expensive cables to run wire for those surround sound ...Interconnect cables are important-in that your system won't work without them. .... If you use a rack or shelves for your AV gear, remember to put the amplifier or ... the projector remote; Power up the home theater system with the receiver remote ...
How to fix sony stereo protection - YouTube
? 1:31
https://www.youtube.com/watch?v=oG17QKiI_E8
Feb 28, 2014 - Uploaded by dallas1999fan
Step 1 take apart Step 2 spin the fan Step 3 unplug the powercable Step ... his fault that your system is not fixed. i have the same stereo system and it .... Sony MHC-EC909iP Shelf SystemFeatures & Review - Duration: ... Red Blinking Power Indicator Denon Receiver AVR-488 - shuts off - won't stay on etc.
Understanding Home Stereos, Amplifiers, Speakers, and ...
Dec 25, 2015 | Audio Players & Recorders
How do i change tuner channels
This is a power amp, change the channels on the tuner:
May 26, 2014 | Teac A-H500 Amplifier
Amplifier keeps going on to standby
Your amplifier more than likely has DC Offset, a damaged amplifier. If you are interested in having your Teac repaired, please refer to my website, audioserviceclinic.com. You may contact me there. Thank you.
Apr 16, 2014 | Teac Audio Players & Recorders
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
Teac amplifier av-h500
rush it to a service centre as something has blown on it it is protecting the speakers from damage
Jun 14, 2010 | Teac A-H500 Amplifier
The volume will not turn down
Do the volume controls on the stereo itself (not the remote) work? Try using a universal remote to lower the volume.
Dec 28, 2008 | Teac Audio Players & Recorders
TA-N9000ES Amp - Standby light constantly blinks - no sound
The flashing light is indicating that a fault has been detected, and it is staying in "protect mode". First disconnect all cables from the processor (except the power cord) and then power up the processor. This will eliminate the possibility of a shorted cable or a problem with any connected components. f the light still flashes, there is an internal problem and the processor will require profesional service.
Oct 09, 2007 | Sony TA-E9000ES Amplifier
Open Questions:
Teac A-H500 Amplifier Logo
741 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
