Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
Frig runs but not cold
This is fairly new frig, working good but couple of days ago, the uper/bottom side is getting warner, something is not working to make it cold as previously. Please help!..
  • 1 more comment
  • jwhymns Feb 13, 2008
    Fridge not cooling relatively new - about 1 year old
  • Housetroll Apr 23, 2008
    I am having a similar problem. My refrigerator is running almost all the time but is not cooling like it should. I checked the fan, which is blowing air in the freezer and the refrigerator. I have also checked for ice/frost buildup and there was none. It is not making any strange noises...just not cooling properly and running all the time. (It does not have an ice maker)
  • Anonymous Sep 05, 2008
    I went out to get repaired. The repairman told me that it was the relay to get it replaced, I did and I was tolc that the compressor was not working? What can I do it is fairly new? HELP???
    President:
  • 1,314 Answers
Sounds like the beggins of a defrost promblem open your freezer and look at the back wall of the freezer cabnit and see if there is heavy frost there let me know and how old is it
Posted on Jan 13, 2008
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Fridge quit working a month ago, unplugged it and when i plugged it back in, it started working again. now it quits working all the time, but when i shut door firmly it starts up again and stays cold for a...
You don't say how old the frig is ... you cant have a frig run like this. On one day ... off the next ... slam the door and it works ... Either get a new frig of get this one repaired professionally. Probably best to get a new frig. I would guess minimum service call charge will be $250.00
Apr 05, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
Vegetable bin keep freezing food. Model # ED2CHOXKQ05
That can be the result of a couple things. Check to see if you hear the fan running in the freezer side? If not, since cold air falls, the cold air could be migrating from the freezer into the frig bottom section through the air duct hole in the back of the frig behind the crisper drawers. If the fan is running the check the air damper in the top left of the frig section. If the frig side is cold enough you should not feel air blowing through. Air flow is only very slight. You will have to remove some plastic cover or duct piece to see if it is closing. If the air damper seems to be working properly, you may have a refrigeration problem indicated by frost build up on the lower part of the freezer back wall. You may want to call in a pro at that point. Hope this helps point you in the right direction. Good Luck
Mar 12, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
We have a 5 yo Maytag side-by-side frig. A few days ago the frig started making a buzzing sound that happens every so many minutes and lasts a couple of min. Today it started dripping water from the port...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Maytag Refrigerators
Refrigerator/Freezer not getting cold
Is the fan on the condenser coils spinning? (back side of unit behind the bottom access panel.)
If it is not, the heat extracted from the fresh food/freezer compartments is not being sufficiently dissipated.
As a short-term fix, you can aim a box fan (a regular ol' room/window fan) at the condenser coils.
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Oct 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer cold but not frig. section
Switch off frig and let it completely defrost.
Jun 27, 2008 | Maytag MTF2155GRQ Top Freezer Refrigerator
sounds like the start of a defrost issue. check the back wall of the freezer. there should be No Ice forming on that back wall from midway down or lower. If so, send me a model number and I can further assist you. I'm factory authorized for Frigidaire Appliances and am Confident that I can help you through this repair.
May 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Frig just not Cold
Check to see if air is blowing into refrigerator compartment.If no air is blowing.It may be that the settings on your dials are not right.If they are and air is not blowing,your evaporator fan is not working,or may be obstructed.
Dec 03, 2007 | Refrigerators
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
145 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
