Question about One For All Kameleon URC-9960 LCD Touchscreen Remote Control
Batteries My remote is too sensitive and it goes through batteries like no tomorrow. Can this be adjusted?
  • Anonymous Apr 22, 2009
    By sensitive I think they meant that the backlight comes on too easily and depletes the batteries. Not supposed to do that.
    Problem Solver:
  • 5 Answers
I'm not sure what you mean by 'too sensitive' but I've had many programable remotes that are picky about how they are programed. Example: Phillips Universal Learning remote, when programing new buttons, I had to be careful not to hold the button on the original remote too long or when I tried using it, it would flip through about 5 channels at a time.
As far as batteries depleting too fast, make sure you're using only new batteries of the same type. Try using slightly more powerful batteries, look for the mA rating. Anything 2500mA or higher should work well. If you have the book for it, see if it reccomends a certain type of battery. If it ends up that the remote just goes through batteries too fast, think about rechargeables. Lithium are good and NiMh have become much better then they used to be.
Hope this helps.
Posted on Jan 13, 2008
Here is a link to help you with this problem! I had the same thing happen to me.
http://www.remotecentral.com/ureview/77.htm
Posted on Feb 05, 2011
How do you re-align a Wii remote?
To Adjust the Wii Remote Pointer Sensitivity, follow these steps..
Wii
  1. Access System Settings.
  2. Select "Sensor Bar."
  3. Select "Sensitivity."
  4. Aim the Wii Remote at the television.
  5. Use the + and - buttons on the Wii Remote to adjust sensitivity until only two blinking lights appear.
  6. Press the A button when done.
Wii U
  1. From the Wii U Menu, select "System Settings."
  2. Using the Left Stick, scroll to the "Wii Remote and Sensor Bar" icon and press the A Button.
  3. Select "Adjust Wii Remote Pointer Sensitivity."
  4. Tap "Next."
  5. Point the Wii Remote at the sensor bar and press the A Button.
  6. With the Wii Remote pointed at the sensor bar, press the - and + Buttons to adjust the sensitivity so that only two white dots are visible in the black window.
  7. When you are finished, press the A Button.
  8. On the Wii U GamePad screen tap "OK."
Please
Dec 14, 2017 | Nintendo Wii Console
I lost my arrow what can I do thank you
First, check to make sure the lights on your remote are still on. One thing that will help is to replace the batteries. Also, get closer to the sensor bar until you see the arrow. At that point, you can go into the Wii Settings and adjust the sensitivity. Adjust it until you can be far enough away to see the cursor.
Jan 24, 2011 | Nintendo Wii Console
Alarm too sensitive keeps draining battery unable too diagnose key phob settings
is the battery draining because the alarm goes off continually? if you can find the brain module, there is an adjustment knob for the shock sensor on the side opposite the main wiring harness. counter clockwise will decrease sensitivity.
Feb 21, 2010 | 473L 3-Button Mini Remote
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Sep 09, 2009 | Basic Remote Vehicle Alarm System
We live in Phoenix Az. We have a 2005 Honda Accord 4dr LX 4 cyl, automatic, AC with factory alarm. The alarm goes off "at will" when parked at home, in parking lots or wherever. It just went off when a...
do you have a remote for alarm? if yes adjust sensitivity with remote push to arm and hold. if you have a sensor under the hood adjust screw on top of sensor.
Jul 22, 2009 | Honda Accord Cars & Trucks
Over sensitive car alarm
at the control module under the hood usually there will be a know or a screw of sorts to adjust sensitivity
May 01, 2009 | 2006 Ford F-150
The pointer hand is not showing on the tv screen
it is probally your sensor bar try moving that or go to sensor bar settings and change settings there
Jan 24, 2009 | Nintendo Wii Console
Remote doesn't work. new batteries installed.remote doesn't lite up when any buttons are pressed
Double check that you have the batteries the right way round as the remote is polarity sensitive also make sure the batteries terminals are making proper contact. Then try again.
Please remember to rate this solution.
Dec 08, 2008 | ViewSonic Televison & Video
Blurry pictures
Check to see what the setting is for Image Size (I have sony cybershot DSC-w50). On the camera itself, it is the button on the bottom. My camera was on the 8"x10" size and I was getting blurry shots (especially with people in them). I switched it to the 4x6 print size and it seems to be much clearer.
Nov 24, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
No Remote
The remote have to work with new batteries. You can check the board where the components are mounted and resoled any that look bad. In your case it could caused by a leaky diodes or a bad solder. All can be replaced at a local electronic or hardware store and they're easy to replace Possible batteries problems: 1 batteries are not making contact properly inside the remote. Test by cleaning connections of the batteries and the remote. 2 battery charger is bad and isn't actually charging the battery. Test by charging on another charger if possible. 3 batteries are bad and are not actually recharging. test by using other batteries if possible. 4 other, unknown, internal remote problem. buy a new one.
Dec 28, 2005 | RCA RS2044 Shelf System
One For All Kameleon URC-9960 LCD Touchscreen Remote Control Logo
209 people viewed this question
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
