Question about DCS (WOTD-227) Double Oven
No heat in either oven
Have electricity to ovens but elements not heating-dcs wosd-230
  • rudybagga Jan 14, 2008
    breaker checked- double pole 50 amp breaker with both poles seemingly on. Lights on panel and inside oven. To check wall connection it takes 3 strong men wuith good backs as this builtin oven weighs 400lbs. Is it possible to check voltage without removing.
    Sergeant:
  • 288 Answers
May I please have some more information. How do you know you have electricity, because the display is on, inside lights etc. Have you checked the voltage from the wall? It is possible on 220v appliances that 1/2 of the breaker has tripped, thus all the 110v systems work (like lights) except the heating elements, which are 220v. Because both ovens have the same problem, its most likely a power source problem.
Posted on Jan 13, 2008
  • Rob Luna
    Rob Luna Jan 15, 2008
    Is there a panel in the cabinet that can be removed so you can gain access to the connection? Or you can remove the front panel that has the control knobs on it. There will be a bunch of stuff inside, what you are looking for is 3 or 4 large wires coming from the back, 1 black, 1 red,(it should be red, it may be black also with a tag on it) and depending on the configuration, a white and/or green, as these will be the power source. There may even be some fuses there. They will be the big round type, looks kind of like a bullet. A volt/ohm meter is critical here if you want to check any further. According to you the lights and panel are working, then the 110v systems are working, meaning you are getting 1 leg of the 220v system, only the 220v, like the heating elements are not, so its a good chance that its a bad wire connection, or fuse that is the problem. Without a meter, this is as far as I can help you.
    Scholar:
  • 128 Answers
DCS by Fisher & Paykel
5900 Skylab Road
Huntington Beach, CA 92647 spacer.gif no heat in either oven - contact_general.gif://i.fixya.net/uploads/images/contact_general.gif" alt="contact_general.gif" class="h_mi" /> no heat in either oven - spacer.gif spacer.gif 888.936.7872
949no heat in either oven - spacer.gif spacer.no heat in either oven - contact_tech_support.gif
<img src= spacer.gif 888.936.7872 no heat in either oven - contact_service_parts.giffixya.net/uploads/images/spacer.gif" alt="spacer.gif" class="h_mi" /> no heat in either oven - spacer.gif contact_service_parts.gif no heat in either oven - spacer.gif spacer.gif 888.936.7872 spacer.gif spacer.gif no heat in either oven - contact_tech_questions.gif contact_tech_questions.gif techsupport@dcsappliances.com spacer.gif
My DCS WOS-230SS top wall oven begins to heat up normally but then stops heating, the fan comes on, then begins heating up again. Got to 170 then went no higher. Could it be the element?
This is a tough question because we haven't mention the make and model number you should add that so we can help you better but normally if the top oven is not working properly it may have thermostat problem or it could also be control panel problem can you tell more information especially the make and model
Sometimes you can take it out and it's not working properly and take that oven and put it in self-clean mode and it might fix problems
Mar 27, 2018 | DCS Ovens
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
DCS WOS-130 oven won't turn off. I've turned the breaker off and back on but each time the oven starts heating without turning it on through the controls.
This sounds like a stuck relay on the control board or in rare cases a short to ground in the oven element itself. Test the oven element terminals to the case. If there is continuity then replace the element. If it checks Ok then more than likely there is a welded relay on the board. you can try tapping the relays on the board. Sometimes this jars the contacts loose and things work again. Be prepared to replace the control if this is the case.
Feb 12, 2014 | DCS WO-130 Stainless Steel Electric Single...
GE Profile JTP85 (installed 1998). The lower heat element in the lower oven will not heat. I can make the upper element heat up by using the BROIL function, but neither element gets warm on BAKE.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 11, 2010 | GE JTP85 Electric Double Oven
My whirlpool oven was preheating for 45 min and only got to 230, but the broil setting works just fine. What is going on, is it the baking element?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
heatman101
Nov 25, 2010 | Stoves Ovens
Top oven will not turn on elements, bottom oven turns on elements
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 10, 2009 | Whirlpool GBD307PR Electric Double Oven
Amperage on Kenmore Double Oven
30A
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 17, 2009 | Kenmore 47763 Electric Double Oven
NEED HELP ON DCS WO-230 DOUBLE OVEN
there are 2 screws at the top outside and 2 or 3 on the bottom of the display panel. remove those and the panel should lift off the mount. remove the ribbon cable and 4 screws for the display and replace.
Oct 05, 2008 | DCS WO-230 Electric Double Oven
DCS (WOTD-227) Double Oven Logo
465 people viewed this question
Top DCS Ovens Experts
ashburton
Sal De
Joyce Nokleby
Are you a DCS Oven Expert? Answer questions, earn points and help others
