Question about Samsung SyncMaster 216BW Monitor
New Monitor Installation
After loading the installation CD and connecting the power and signal cable, I get a "Check Signal Cable" message floating around the screen!. I checked all the signal cable connections and they were OK. So I'm now stuck! Any help out there???
Chuck
    Novelist:
  • 139 Answers
Does your computer have more than one video adapter installed. If so, try plugging into the other one.
Posted on Jan 13, 2008
After having unplugged my computer from router for a period of time when I hooked it back up I get no signal msg on monitor how can I fix it
Troubleshooting Network Problems on the Dell V525w and ...
www.dell.com/support/article/us/en/04/SLN129390?c...l...
DellMay 13, 2015 - My Account .... Back to Top ... The printer, the computer, and the access point (wireless router) are ... Try unplugging other devices that may cause a conflict with the USB ports. ... with only the VPN and no other network at the sametime. ... message during installation indicating that the printer does not have ...
Connection Keeps Dropping Off - NICs - Components - Tom's Hardware
www.tomshardware.com > Forum > Components
Tom's Hardware Guide
Mar 8, 2010 - 30 posts - ‎23 authors
I will sometimes lose my internet connection within windows. ... When I hook up the cable modem directly to the host PC everythinh ... My desktop has a linksys wireless NIC and I have no problems with it ... Comcast says when the cable box loses it'ssignal, the router can't get good communication back with ...
No Signal Message On Monitor And PC Gets Restart?
forumarray.com/no-signal-message-on-monitor-and-pc-gets-restart-1421...
Nov 18, 2015 - started recently, when I boot my PC, the screen shows message: no signal and screen stays dark. ... then to get the signal back again, i must restart mysystem. then after boot up, i get ... Dell :: Having Trouble With Display On External Monitor .... laptop screen working until I unplug the 2nd monitor and restart my computer. What Is A Signal Cable On The Computer - Logo
Jan 17, 2016
BSOD When Unplugging Ethernet Cable - Logo
Nov 19, 2015
Monitor Doesn't Get Signal From Computer?
Nov 13, 2015
Cable Unplugged Network - Logo
Mar 22, 2013
More results from forumarray.com
Jan 27, 2016 | Dell Computers & Internet
Problem with the monitor
hi,
first of all,try to connect the cable to other device(laptop) to see if is working,because if you receive the message"No signal" then the monitor is working but the cable/signal did not cross to the monitor,then is working with other device then try again or check if you can connect the monitor with different port if you monitor has one vga/dvi or hdmi.
Aug 25, 2014 | Acer Veriton M460 Micro Tower Core 2 DUO...
Monitor says to check signal cable
get a new power cable for tower/computer. u can call i wat u want. new power cable for computer not moniter. or connection is incorrect. hope it helped.
Dec 05, 2011 | Samsung Computers & Internet
S24a300b problem, not detected by pc. message on display say "check signal cable".
Check signal cable means that your monitor wire is not connected properly.
So remove your cable connect it tightly once again.
Tightly connect with cpu and power supply.
Thanks for using fixya
Aug 19, 2011 | Samsung S24A300B Monitor
I have a samsung syncmaster 930b attached to an HP Pavilion Slimline s5660f Desktop PC, plugged into the DVI port of the PC. However, I cannot get the monitor to come up. There is power to it. I get the...
from user manual troubleshooting section
(When connecting D-Sub cable) Check the signal cable connection. (When connecting DVI cable) If you still see an error message on the screen when the monitor is connected properly, check to see if the monitor status is set to analog. Press Source button to have the monitor double-check the input signal source.
Source button Activates a highlighted menu item.
/ Push the 'SOURCE', then selects the video signal while the OSD is off. (When the source button is pressed to change the input mode, a message appears in the center of the screen displaying the current mode -- analog or digital input signal.) Note : If you select the digital mode, you must connect your monitor to the graphic card's port using the DVI cable.
https://images10.newegg.com/User-Manual/User_Manual_24-001-063.pdf ninth page in user manual
source button fourth from the left when facing monitor. looks like a box with an arrow pointing left.
Mar 05, 2018 | Samsung SyncMaster 930B 19" LCD Flat Panel...
I'm currently installing my new SyncMaster 2280HD Monitor to be used for now just as a monitor. When I turned on the computer onscreen all I get are two floating boxes that say AV in the upper left...
It sounds like there is a connection issue between the computer and monitor. Make sure the cable connecting the computer and monitor is securely fastened on both ends. If you verify that it is and the problem persists, try using a different cable.
May 27, 2011 | Computers & Internet
I have a samsung 17'' lcd monitor.when i power on my monitor without data cable i got a message on screen CHECK SIGNAL CABLE.when i connect data cable my lcd is going to power off.please help?
The message says that the monitor doesn't receives signal - which is normal. Since the problem appears only after you plug in the cable in means that the problem is located there - something is wrong with your pc, most likely the video card has died.
Oct 03, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Mitsubishi diamond pro says "no signal"?
You have tried the monitor on more than one known good computer, yes?
I believe about 4" inside this monitor in the back the vga cable or connector connects to a board with an in-line connector. Can you see if this connector (internal to the monitor) in connected?
Good luck...
Mar 02, 2009 | Mitsubishi Diamond Plus 100E Monitor
No signal on startup
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
Dec 29, 2007 | Princeton Digital VL2018W Monitor
Samsung SyncMaster 216BW Monitor Logo
400 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
