Question about Uniden 5.8GHz Cordless Phone
Out of range shows on main handset of cordless phone
Out of range is displayed on the main handset , and does not work but other 2 cordless handsets do
  • 9 more comments
  • Anonymous Feb 27, 2008
    I have the same issue. I bought a set of DSS7815+1 to go with my DSS7855+1. I have somehow managed to register my two new handsets with my original base unit, but cannot get the original two handsets to work. They will not deregister, and the screen says they are out of range.
  • Anonymous Mar 14, 2008
    OUr old phonw works but neither of the twin handsets work, just show out of range message whilst phone is ringing
  • Emboo Jul 19, 2008
    My RadioShack 2.4 GHz cordless phone is displaying the message "Out of Range" Handset #1 New: 99. Cant use the handset.
    How do I fix it
  • Anonymous Dec 22, 2008
    I have Uniden WDECT 2355+2 cordless phone. Bought a new set to use only one handset (this model supports 4 handsets) but new handset keeps showing "out of range" and battery is slow to recharge.
  • Anonymous Dec 31, 2008
    my main handset says out of range, I tried to unplug battery and press #& * but it didn't reset any other ideas? I have 5180 5.8 ghz
  • lconnol1 Jan 26, 2009
    I have the same problem and did the above and it will still not work
  • jbarmen Feb 21, 2009
    I had two handsets, on two different systems, both Uniden, with this problem. The posted solution worked like a carm. The trick was to keep the # and * keys depressed while plugging the battery back in, though I have to admitt that little proceedure was a little tricky. John.
  • Anonymous Mar 14, 2014
    I have amplified cordless phone that I just purchased and would like to know how to get the handset to ring louder ring louder marymcneel@att.net
    Purchased amplified cordless phone D3097 and would like the hand set to ring louder
  • Anonymous Mar 18, 2014
    handset was disconnted overnight. when replugged, handset displayed searching/handset out of range. what steps do I take?
    handset was disconnected overnight. when reconnected next day, phone displayed "searching" handset out of range.
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Posted on Jul 06, 2008
  • jerf william
    jerf william Apr 04, 2014
    my phone is vtech
  • Keced Joseph
    Keced Joseph Feb 06, 2015
    Thanks for helping.
  • 3 Answers
I successfully reset Radio Shack (Uniden) 5561 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near the LCD window. The display will indicate "EEPROM/RAM cleared!!" and will return the handset to the factory default condition - looking for a base to register to.
Posted on Mar 23, 2008
So, I've 2.4 GHz Digital, RadioSHack: I had this problem where I could only see the "Out of Range" message.
So, I did the following-press the menu Menu/Del, then go to System Reset, then go to Replacing Base, then it will give you "YES" or "NO"-select YES. Then it will tell you to place the handset on the phone (phone base)-when you do that, it will tell you to wait while it is connecting-and it should connect shortly.
Hope this works. I tried the other steps and wasn't able to fix the problem.
Posted on Jul 14, 2010
Thanks it worked
Posted on Mar 05, 2012
  • 1 more comment
  • mon praport May 29, 2013
    no way
  • TJ Bullet Sep 20, 2013
    My Uniden D1463 will not register.
  • martyn jones
    martyn jones Mar 16, 2014
    Its as easy as the man say's Big Thanks.............
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
Registering.
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
I have uniden cordless phone model dxa15588-2, how do I register handset on base?
1-Press the hangup key (represented by a red phone) and the "#" key at the same time for at least five seconds.
2-Select "Deregister hs." Choose the handset and press the "Select" key (which also shows an envelope for messages).
3- Choose "Yes" to confirm deregistration. The phone clears its registration information from the base and deletes the link from its memory. The message "Handset not registered -- place handset on base to register. See owner's manual for help" now shows on the display. If you are out of range of the base, "Out of range" shows.
4-Place the handset in the base charging cradle. The phone automatically selects a new security code from those stored in the base.
5-Make sure your phone is working again after "Registration Complete" shows on the display
Hope this will Help. Thank you for using Fixya !!!
Nov 17, 2010 | Uniden Cordless Phone
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
May 05, 2009 | Lands Phones
Handset No2 displays out of range message
Please check that you have correctly registered the second handset to the base. It may be necessary to de-register the second handset and then re-register it. "Out of range" just means the second handset is not within range of the base phone it was registered to.
Mar 08, 2009 | Uniden TRU8885-2 Cordless Phone
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Uniden 5.8GHz Cordless Phone Logo
9,719 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
