Question about Averatec 3200 Notebook
Need new adapter?
Laptop overheats when plugged into electrical outlet. If I try to use computer on just batteries, seems to be okay. Will not overheat if computer is turned off and use adapter to charge battery. Any answers?
    Scholar:
  • 163 Answers
Clean the heatsink and fan assy and apply some thermal grease to the cooling pad on the CPU.. Its throttling back on batt. and not running full tilt. Vents are plugged/Obstructed/Clogged..
www.ikenfixit.com
Posted on Jan 13, 2008
HP Compaq NC8430: Laptop does not want to charge battery
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Jan 30, 2013 | HP Compaq nc8430 Notebook
My laptop battery willnot charge
For this kind of issue, you may try the following troubleshooting steps:
Take your laptop battery out, plug in the charger and see if the laptop works.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.Remove the Battery Sometimes it's as simple as a seated battery.
hope this helps
Jan 08, 2013 | Advent Computers & Internet
Laptop wont recognize charger
Maybe you did damage a component due to overheating? What caused the Laptop to overheat? Does the battery work on another laptop?
Dec 29, 2012 | ASUS Computers & Internet
Inspiron 1545-my AC adapter doesn't seem to charge my battery
Check the LED Your Dell Inspiron 1525 offers five small blue LED lights on the front left corner of the laptop that display the status of various areas of your machine. The middle light shows the charge status of the battery, with a solid light indicating charging. The light changes to a blinking sequence as it nears full charge and turns off when full. Without the adapter cord plugged in, the battery LED turns orange as the charge runs down. Check the color of the light to verify charging status.
Verify Connections and Power
Start with the simplest cause and work backwards to the laptop. Use a different electric device to check for electricity from the wall outlet. Verify that the connections of adapter cord are tight and secure at the wall outlet, the brick and the laptop. Check the adapter cord's brick for a small LED that lights to indicate the presence of electricity.
Check the Battery
Battery issues can prevent proper charging, ranging from something as simple as a mis-seated battery to as serious as a completely dead battery. If the adapter seems to be functioning properly, try removing the battery and checking the small metal contacts in the laptop. Clean any corrosion or dirt from them to ensure a solid connection. Reseat the battery so that it clicks securely into place. If in doubt, try purchasing a replacement battery and see if that works.
Check the Adapter
Unless you keep your adapter cord in one place and never move it, every day use of the cord can cause the wires inside the insulating material to fray and kink. This wears them down, and can cause short circuits. The circuitry within the brick can also short out, preventing the delivery of the proper amount of voltage to the 1525. Use a voltmeter to double check that the cord is supplying the correct number of volts to the Inspiron.
Inside Problems
Internal issues can prevent a battery from charging, such as short circuits and a broken adapter port. The adapter port, the small opening you plug the end of the adapter cord into, is attached to the motherboard to carry the electricity to the various internal electronics. If this component breaks loose from the motherboard, the electricity can't go anywhere. A repair shop can fix this, as well as diagnose any other short circuits, for you.
Aug 09, 2012 | Dell Computers & Internet
Dell Inspiron 1521 battery not charging
Laptop batteries power a laptop when it is not connected to an electrical outlet. If the laptop battery fails to charge when the laptop is plugged into an electrical outlet, the battery is likely dead and needs to be replaced. Unfortunately there is no way to fix a dead battery. However, while a dead battery is the likely cause, it is not the only cause. The AC adapter may be broken, in which case the battery won't charge, or the battery contacts may be dirty and need cleaning. Prior to replacing the battery, perform simple tasks to ensure a dead battery is the cause of the problems.
1.Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2.Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3.Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4.Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5.Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6.Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7.Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
Sep 01, 2011 | Dell Inspiron 1521 Laptop
Wont turn on
1.Plug the Inspiron's AC power cord into a power outlet and try to power on the laptop again. By far the most common cause of a laptop's not powering on is a dead battery.
2.Plug the AC adapter into a different outlet to check for a "dead" outlet. If you have the cable plugged into a surge protector, plug the cord into a different slot on the surge protector or "bypass" the surge protector by plugging the cable into an electrical outlet. If the Inspiron now powers on, replace the surge protector or have an electrician examine any "dead" outlets in the home.
3.Open the battery bay on the underside of the Inspiron by sliding the battery bay latch release lock upward and the battery bay latch release to the right. Once both latches are released, the battery bay should open.
4.Remove the battery.
5.Purchase a compatible replacement battery for laptop. Be aware that using an incompatible battery can cause damage to your computer. If you have any doubt as to compatibility, the best option is to purchase the replacement battery directly from your laptop's manufacturer.
6.Install the new battery by following the battery-removal procedure in reverse order. Once the new battery is installed, try again to power on the laptop. If there is still no power, seek professional repair advice.
I hope you find it very helpful.
Aug 25, 2011 | Gateway Computers & Internet
Not charging
1. Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2. Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3. Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4. Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5. Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6. Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7. Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
Thank you. Please rate me.
Aug 10, 2011 | HP Pavilion dv6000z Notebook
When i plug in my laptop, the light indicating that the laptop is plugged in does not go on.
Hi, if you don have tester to check if your adapter is working remove the battery and plug in the adapter in electric outlet, plug the other end to your device and power on your laptop if it works means that your adapter is okay. and the led indicator is just busted.
Jun 16, 2011 | Computers & Internet
Laptop battery is not charging
you need to repalce the battery, it will only work on AC power only now as the power surge damaged the battery, thank your lucky stars that the surge didn't blow the whole laptop because 98% of the time it does!
Nov 16, 2008 | Computers & Internet
Laptop Won't Boot
You'll need to troubleshoot your laptop in order to know what the exact problem is. First try to plug it in with the battery on and try turning the laptop on. Next would be to remove the battery and plug the computer. If this doesn't work then it's definitely the AC Adapter and you'll probably need to call toshiba to purchase a new one from them or if you're still under warranty then have it replaced. They also have some qualifiers on whether an AC adapter or battery is qualified for replacement even if it's under warranty. Just call them on 1-800-457-7777 and ask their technical support reps about this.
Sep 17, 2008 | Toshiba Satellite A105 Notebook
Averatec 3200 Notebook Logo
56 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
