Question about Sony DAV-DX255 System
Push power protector?
Is there some sort of reset button inside system? when turned on it says to push power protector
SOURCE: Push Power Protector
I had the same. It was caused by the speaking wire ends touching the unit. I was just setting it up and had not fully connected everything. They were just loose. In general i think the message is trying to say check the power or check all your cables for short circuts.
Posted on Feb 17, 2008
  • 19396 Answers
SOURCE: it says push power protector on my new sony surround system
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Posted on May 04, 2009
Service Dude
  • 201 Answers
SOURCE: "Push Power'' and ''Protector"
your sound output IC is short circuit and needs replacement.
Caused by :
- Heat playing full blast for long
- speaker wires schorted
- or bigger or more speakers was aplied
THank you
Posted on May 13, 2009
  • 10594 Answers
SOURCE: why does push power protector keeps flashing in
This is an error massage and comes when home theater got some internal problem specially in amplifier output section that can have defective output IC etc.
It is not user level repair and requires qualified tech for fix.
Posted on Sep 14, 2009
  • 1922 Answers
its in standby, try it again, if it does it repeatedly theres a problem in the switching power supply not letting it power-up to save components
Posted on Oct 18, 2009
SOURCE: push power protector showing up in sony dvd home theater system
Always be the audio amplifier IC damaged
Posted on Jun 24, 2010
0 characters
1 Points
if your pushing the power protector to on back its a resettable fuse an you have another insue inside shorting it out
Aug 03, 2014 | Sony Dream Home Theater System, DAV-DZ120...
If it really says, "Push power protector", there should be a reference to it in your owner's manual. Check there first.
Feb 05, 2014 | Sony BRAVIA® DAV-HDX576WF Theater System...
Do a cold reset, page 90 of your manual. Push power button, stop button and disk eject at the same time. Wait 5 minutes and turn back on. Look on page 90 of the manual. This worked for me after trying over a year. I beat I didn't have 25 hrs on mine. Good Luck
Nov 30, 2013 | Sony BRAVIA DAV-HDX267W Theater System...
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Dec 20, 2012 | Sony DAV-HDX500 System
Turn demo mode off on Sony Bravia home theater
On your remote;
Press the Home button
Scroll left to settings
System settings
Auto-start up - go through setup and select "Home" (not store)
Dec 06, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Protector and "push Power"
Please check speaker wires should be properly connected and not touched / shorted.
Push Power Protect is error sign when unit got problem in Power Amp area and mostly its Power Amp Out IC failure.
I would suggest to ask Sony for warranty cover.
Nov 30, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Home Theater Systems
Sony DAV-DX255 System Logo
98 people viewed this question
Top Sony Home Theater Systems Experts
Dennis McCollum
Electro Med Services...
Are you a Sony Home Theater System Expert? Answer questions, earn points and help others
