Question about Baumatic Louisiana Dual Fuel (Electric and Gas) Kitchen Range
BKRC21V Electric oven, gas top
When I select temperature in either oven, a fan comes on with cold air out of the top of the door - is that normal? It stays on throughout the whole process.
It takes 35 minutes for the large oven to heat to 225, and 25 minutes to heat the smaller oven to 225. The times seem excessive, so what could be wrong. Once I open the doors to tend to food the temp drops quickly and takes ages to warm up again.
The stove is new, so I'm assuming we're experiencing teething problems - or a difficulty in understanding instructions!
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Read your owner's manual. That will answer all your questions.
Posted on May 06, 2017
What are the dimensions of a chef baroness integra gas wall oven
You need the Chef Model number, then click on the model and then on 'More'.
chef integra baroness wall oven 92 60 chef Compare Cheap chef integra...
Chef EXC627W Wall Oven
Compare prices $849.00 Chef EXC627W 60cm electric fan forced wall oven with separate grill and 60 minute timer in white Separate grill 60 minute timer Easy clean formed shelf supports Cooler door temperatures with air cooled door Wall installation Cooling fan Oven size (cm): 60 Oven - internal dimensions (h x w x d) (mm): 376 x 475 x 432 Separate grill - internal dimensions (h x w x d) (mm): 216 x 475 x 432
Specifications Style of Oven
Separate grill/wall
Oven Type Electric
Width 888 mm
Depth 595 mm
Height 573 mm
Or contact them direct
Welcome to Chef
https://www.chefappliances.com.au/Explore Chef's range of products! ... The simple touches that make Chef functional and easy. Fingerprint. Anti-fingerprint. A special stainless steel finish means our ovens stay free of messy prints. Cooktop options. Gas, electric solid or ceramic. image 1. Boils faster than gas? Easy. The Induction cooktop provides modern, ...
Apr 08, 2018 | Ovens
I have just purchased a Neff U17M423GB built under double oven from JL. When I put it on preset timer for the bottom oven, the fan starts blowing cold air out of the vents above the top oven. When t
if this is gas it calls the induced draft motor to come on for 15 to 20 seconds to clear any residual gas before beginning the ignition process begins. Very normal and a safety feature.
Nov 20, 2014 | Neff Ovens
Can you confirm if the top element should be coming on when selecting just fan oven? If had a look at the over selector switch all appears to be of ok with the switch selecting the top element as well as...
Correct, the grill element should not come on when using the fan oven.
Using the fan oven
The air inside the oven is heated by the
element around the fan situated behind the
back panel. The fan circulates hot air to
maintain an even temperature inside the oven.
HOWEVER
I think you are doing this
Using Hot Air Grilling
This function uses both the grill element and the
fan. Turn the function control knob to the
appropriate position. To achieve optimum
cooking results, it is advisable to place the oven
shelf in the middle position while the oven tray
should be inserted at the bottom.
IMPORTANT: When using the hot air grilling
function, set the thermostat knob no higher
than 175°C, which is between the 150°C and
200°C setting, to avoid overheating the front
of the appliance.
The door MUST be closed while Hot Air
Grilling.
http://kitchen.manualsonline.com/manuals/mfg/zanussi/zcm930x.html?p=10
Dec 01, 2017 | Zanussi ZCM930X Dual Fuel (Electric and...
Stoves 900DFa oven cuts out
Hi.
The most probable cause is failure in your panel cooling fan 9not the one inside your oven)
If the appliance switches on again after 15 - 20 minutes then the fault is most likely here.
Unfortunately as you have gas the you will need a Gas Safe Certified engineer to repair
Regards
aardvark repairs
Nov 18, 2009 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Ge oven turns off by itself, and sometimes gives
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
Instruction manual
HI SIR
When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
Multifunction Oven Function Selections
2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
8. Fan-assisted Baking or Patisserie Setting
 - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
top
Advanced Oven Features
Cavity Cooling
The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
Triple Reflective Door Glazing
Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
Wipe Clean Enamel (Extra Optional)
Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
Drop Down Grill Element (Extra Optional)
The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
top
The Electronic Timer
Normal Baking
Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
top
Fan Forced Baking
Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
top
Grilling
Function 5 & 6: During grilling the door may remain closed or completely open.
This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
Sep 11, 2008 | Ovens
Oven door locked - jenn air
My Jenn-Air double oven locked after a clean cycle. My model (JJW8630) has a series of slots cut in the top of the door. Take a piece of stiff wire, coat hanger, and bend a right angle about 1/2 inch at the end, feed the wire into the 3rd or 4th slot from the center on the right hand side. Turn the wire so that the bent piece is on the top and push the wire so it engages the lever which latches the door shut, it is spring loaded and moves easily.
Once the door was opened, I removed the temperature sensor, held by 2 screws, from the top of the oven and eased the wire out to get to the connector. The faulty sensor was reading 4.2 k, at room temperature it should be just over 1k, while waiting for a new sensor to arrive I stuck in a 1k resistor, ex Radio Shack, so the fan stops running and the door latch can be retracted by closing the oven door, or press the switch on the top right of the door opening.
My replacement part was ordered on line for less than 1/2 the official quoted price.
Hope this helps.
Jul 18, 2008 | Jenn-Air JJW8430D Electric Double Oven
Hotpoint bottom oven
Cooking is determined by 3 things so let's look at what they are and what they do.
They are:
  1. The Fan Oven Element - This is very much the same as a light bulb only instead of giving off light it gives off heat. Like a light that is switched On or Off by a wall switch, the Element is switched On or Off by a Thermostat according to the temperature required. In short if the element fails your oven will be cold.
  2. The Fan & Motor - This sucks the air in through the centre mesh and circulates it around the Element and pushes the heated air out of the top, bottom and sides of the back-plate. Fan ovens cannot heat properly if the fan is not running OR if the fan runs too slowly as the motor starts to fail.
  3. The Thermostat. - This is basically an On/Off Switch that responds to the temperature in the oven. If The Fan is running correctly and you are achieving some temperature in the oven, then the fault will be with the Thermostat.
I hope this Helps - Terry
ALWAYS ISOLATE THE POWER SUPPLY BEFORE WORKING ON THEI APPLIANCE!
May 06, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Baumatic Louisiana Dual Fuel (Electric and Gas) Kitchen Range Logo
67 people viewed this question
Top Baumatic Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
ray gallant
Jay Plesset
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
