Question about Samsung CXD2512 25 in. Combo
Disconnecting vcr in a combo
I want to disconnect the VHS deck in my combo tv, is it possible? The TV is a Samsung CXD2512 combo unit.
    Champion:
  • 213 Answers
No can,t do that tv will not work at all if do so.can you put a tape in the tv some time the tv will stay on . if so you have a drity mode switch under the vcr deck. itry to clean.
Posted on Apr 01, 2008
VHS tape not working in Samsung TV/VHS Combo and unable to get the tape out
Must take VCR out to remove tape gently.Cause of problem is usually a dirty mode switch.
Feb 26, 2015 | Samsung CXJ1352 13 in. TV/VCR Combo
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
I no longer have the original remote for my Samsung TV/VCR combo and am using a universal remote. Yesterday I started having problems with the speed of the VCR playback. Mostly, it is too slow, distorting...
U have play back problems on playback SP LP SLP modes tuggles problems.Try website like Remotes.com to buy the tv original remote,have these buttons to set the correct VHS tape play back modes tuggles problems.
Dec 11, 2010 | Samsung CXD2512 25 in. Combo
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
I have a Samsung DVD -VR 357 combo unit and i can't record
I have the Samsung dvd-vr 357. I have had a couple problems with it but I called samsung and they walked me through fixing it each time. I don't know if you have tried this or not but that is my suggestion. The last problem I had was copying from vcr to dvd. I got audio but no video. Problem was it was on dvd when i started it, it should have been on vrc. It should be set on whichever one you are recording from. Hope this helps someone.
Nov 12, 2008 | Samsung DVD-VR357
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
TV shuts off after 10 sec
TV/vcr combo units develop problems in the vcr section,what happens is the cassete assembly draws too much current then the tv senses this increase and it says NO and shuts down,you will not be able to use the vcr anyway because it has a problem and the tv will continue to shutdown until the vcr is repaired,I have seen combo units with the tv working only as long as the vcr is not use.Remove the light you have in the opening and hope the tv works fine by itself.Adding a light is not safe.I hope this inf.helps somehow.Good luck
Sep 16, 2006 | Samsung CXD2512 25 in. Combo
Samsung CXD2512 25 in. Combo Logo
171 people viewed this question
Jerry Greenberg
Jerry Greenberg
