Question about HP Pavilion 9695C PC Desktop
Remove hard drive
I have the case open, the cables detached, some screws removed, but I can't remove the hard drive "yet" -- it seems to be attached somewhere quite inaccessible. Obviously, this is not meant to be so difficult.
  • 1 more comment
  • antares Jan 13, 2008
    I have been unable to access the other side. I went to the HP web site and many YouTube and other videos. There are no green latches and the casing in which the hard drive is installed does not flip out as in many demos.
    Thanks, folks.
    To be clear. I have removed the side panel, disconnected the cables, and removed the two screws on the accessible side of the hard drive.
    The document on the HP web site refers to green latches.
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    There are no such latches, but it says "your computer may not look like this."
    I can feel that there are two screws on the other side but I have not figured out how to access those screws. I tried removing the front panel. It seems to have three latches on each side. I have been able to release it a little but not pull it off. It says having an extra set of hands might help, but I don't really even know if this will give access.
    All the demo videos suggest that the housing for the HD easily comes out. I seriously doubt this is the case with this older machine.
  • Anonymous Mar 28, 2014
    want to remove hard drive
    Sergeant:
  • 263 Answers
The hard drive has screws on both sides so you may have to remove the oder side of your case in order to remove the hard drive
Posted on Jan 13, 2008
    Sergeant:
    Champion:
  • 243 Answers
Did you remove screws from both sides of the hard drive?
ASUS ET27001 hard drive failure. Need to remove the hard drive. HOW TO OPEN THE CASE.
You need tools to open the computer case with Phillips screwdriver with appropriate size. Unscrew the 2 or 3 screw at the back of the case and then slightly slide the cover of the computer case to open. You will see the the hard drive screwed on the inside and unscrew and detach the power cord and data cable.
Sep 21, 2013 | ASUS P4GE-MX Motherboard
How do i safely remove the cable that attaches to the motherboard on my toshiba laptop
Toshiba satellite motherboard removal.
A motherboard is usually replaced for one of two reasons. You either replace a motherboard because it has gone bad, or you replace an older motherboard with a new or upgraded motherboard. In either case you will have to completely disassemble your laptop to even gain access to your motherboard. Fortunately, the Toshiba Satellite laptop can be completely disassembled even if you don't have a lot of technical knowledge.
Turn off the laptop, disconnect the power cable, remove the battery pack and disconnect any miscellaneous cables and peripheral devices. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Attach an antistatic wrist bracelet to prevent shock from static electricity. Static electricity can harm your computer's internal parts. Place the laptop face down, and remove the single Phillips-head screw attached to the hard drive cover. Remove the hard drive cover, then set it aside. Remove the single Phillips-head screw attached to the wireless card/memory cover. Remove the cover and set it aside. Slide the hard drive out of its compartment. This will disconnect the hard drive from the computer. Set the hard drive aside very carefully. Push on the ejector tabs on either side of each RAM module. Slide the RAM modules out of their compartments at a 45-degree angle. Remove them from the laptop and set them carefully aside. Disconnect the antenna cable from the wireless card, and then lift the wireless card out of the laptop. Remove the four retaining screws from the modem card. Lift the modem card slightly out of the laptop, and then disconnect the modem cable from the motherboard. Set the modem card aside. Remove the single Phillips-head screw securing the DVD/optical drive. Slide the DVD drive out of the laptop's frame and set it aside. Remove all marked screws from the bottom casing of the laptop, and then place the laptop face up. Open the laptop as far as it will go. Use a small flathead screwdriver to pry up the keyboard bezel. The keyboard bezel is a small plastic strip sitting between the keyboard and the LCD display. Remove the two Phillips-head screws securing the keyboard in place. Lift up on the keyboard and disconnect the keyboard's ribbon connector from the motherboard. Remove the keyboard from the laptop and set it aside very carefully. Close the laptop. Place the laptop vertically so the LCD display hinges are face up. Remove the two Phillips-head screws from the hinges. Set the laptop down and open the laptop as far as it will go. Remove the four Phillips-head screws securing the LCD display. Lift up on the LCD display, and then disconnect the video cable from the motherboard. Remove the LCD display from the laptop and set it aside carefully. Disconnect the DVD control board cable, the touchpad cables and speaker cables from the motherboard. Disengage the plastic latches on the rear of the laptop casing near the hinges, and then remove the top casing from the laptop's base and set it aside. Remove the two Phillips-head screws securing the CPU fan and heat sink in place. Disconnect the fan cable from the motherboard. Remove the fan and heat sink from the motherboard and set it aside. Remove the single Phillips-head screw securing the motherboard to the bottom laptop casing. Disconnect the USB port connector from the motherboard and remove the jack from its housing. Lift the motherboard from the bottom laptop casing and very carefully set it aside.
Hope this helps.
Dec 13, 2012 | Computers & Internet
How to replace cmos battery on satellite p105-s6217 laptop
Turn the laptop over and remove the battery pack.
From the bottom of the laptop, unscrew the plastic shells securing the slots for memory,
Bluetooth, hard drive and modem.
You may have to remove more than one screw for each shell. Keep all screws in a small container, away from the work area.
Remove the memory (RAM) modules, the hard drive and any optical drives (CD-ROM or DVD-ROM).
Press the clips on either end of the memory slot to raise the RAM module and detach by pulling it out. Work slowly and carefully, to prevent damage to RAM modules or the memory slot.
Do the same for all modules, if you have more than one.
Slide out the hard drive and optical drive. If the drives seem to be stuck, look for any screws you may have missed.
Turn the laptop over and insert a pointy tool under the thin strip at the top of the keyboard. Use the tool as a lever to pry the securing strip loose, while working with your finger to release latches along the length of the strip.
Remove the keyboard by undoing two screws securing it.
Raise the keyboard and disconnect its cables.
Close the laptop lid and turn it around, so that you are facing ports on the back.
Remove two screws from the metal plate around the ports.
Open the lid and remove a single screw securing the wireless card cover; the screw is under the keyboard, which you already removed.
Disconnect cables from the motherboard.
Access the board through the space created by removing the keyboard. Unplug the speaker cable from the motherboard by carefully pulling at its head.
Unscrew and remove Wi-Fi antennas, and detach the wireless card from the motherboard. Unplug thin, ribbon-like cables from the video card.
Detach the display assembly from the base of the laptop.
Loosen any attachments, and pull the casing toward you to detach the display assembly, including the LCD panel, from the base.
With the motherboard completely exposed, unscrew and remove the video card.
Undo two screws from either side of the hard drive housing and detach the drive.
Dismount the CPU heat sink and detach the fan cable from the motherboard by removing five screws.
You can now access the battery board with the CMOS battery attached to it.
Undo two screws to detach the battery board from the motherboard.
Disconnect two cables running from the battery board, and carefully raise the board to detach it.
Replace the CMOS battery by prying it open with a pointy tool. Insert a new battery and reassemble the laptop.
hope this helps
Oct 04, 2012 | Toshiba Satellite P105S6217
Can not open my toshiba laptop
Ok, on a laptop you need to get some cups and label them toput the screws in so you will know where they came from. Remove the PowerCord, Remove the Battery then start removing all thescrews from the bottom of the laptop. Then remove all the devices fromthe bottom of the laptop such as the hard drive, the memory, dvd/cd drive,wireless card, etc. Take note of how the wires are on the wireless card,those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slotfor screw. Some screws on the bottom case in inside of some of the devicecases might have the icon of a keyboard next to it. Those screws hold thekeyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but becareful because a cable might be attached to it. Then remove the screwsthat hold the keyboard in place that are under where the strip was and gentlylift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift thelcd screen off, also note that you will have to pull the antennas cable and thelcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note ofany cables that are attached to the palmrest and remove them then lift thepalmrest off.
Next start removing any screws you see that hold the motherboard to the bottomcase, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory ofwhere things were.
Jun 07, 2012 | Toshiba Satellite A100-S8111TD Notebook
Open laptop to change cooling fan
Jun 04, 2012 | HP Compaq Presario CQ61420us Notebook
How do you remove the hard drive from a acer aspire tower T135
If you are looking at the front of the computer case, you will need to remove the cover on the left hand side of the computer case. There should be two screws holding it in place, located on the back of the tower. Once you have remove the screws and cover, the hard drive will be accessible. Simply disconnect the cables to the hard drive and remove the screws holding it in place.
Mar 05, 2011 | Acer Aspire T135 PC Desktop
I want to get to the motherboard. how many screws are there?
1 Wear an antistatic wrist strap before you start dismantling the notebook. Doing so will prevent static electricity from damaging internal components.
2 Shut down the notebook, and remove its AC power cord and battery. Turn the laptop over and remove all marked screws from the bottom. Raise the plastic shells covering the hard drive, memory (RAM) and wireless card slots, and uninstall the components by lifting off the base. You may have to release locking clips to free the RAM module from its slot.
3 Turn the laptop around and detach the keyboard panel. Using a flat-head screwdriver, push inward on the four small latches holding the keyboard in place to disengage them. Lift the keyboard to remove it, and disconnect its flex cable. Remove the five screws from the exposed landing. Do not undo the screws securing the heat sink and CD-ROM drive.
4 Split the notebook casing open. Insert a pointy or flat-tipped implement between the top and bottom parts of the casing, and maneuver to detach the locking mechanisms holding the two parts together. Work your way all around the perimeter to detach and remove the top casing. Do not apply too much force, or you may break the plastic parts.
5 Remove the hinge covers holding the LCD panel. Unscrew the two plastic hinges to loosen the display assembly and its enclosed LCD screen. Locate and pry open the CMOS battery---a flat, circular component resembling a watch battery---from the motherboard. Disconnect the LCD cables, and detach the panel from the laptop by lifting it up from its position.
6 Undo all securing screws from the chipset and heat sink. Remove the components by gently raising, checking to ensure that you've disengaged all attachments. Remove the CD-ROM drive by unscrewing its attachment and detaching it from the notebook. With the optical drive off, disconnect the speaker's connecting wires and remove the speaker assembly.
7 Unscrew all points of attachment to release the motherboard from the notebook's chassis. Locate and undo all locking mechanisms, such as clips or hooks, to free the motherboard. Remove the plastic inserts for the modem, as well as the PCMCIA and SD card slots, and detach the motherboard. Move the board around a little to release it, and lift it off the notebook.
Feb 05, 2011 | LG E500 Express Dual Series Notebook PC
Remove hard drive
Step 1: Use the following steps to open the case:
  1. Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.
  2. Unplug the power cable and with the power cable removed press the Power button on the front of the PC.
  5. On some cases, it may be necessary to remove the front of the PC so that you can remove the drive cage. If so, press in on the tabs that retain the front cover, there should three to four on each side of the cover and gently pull forward. It helps to have a friend help with this process. Carefully detach any cables that may also be attached to the front cover.c00376513.gif
Step 2: Disconnecting the cables
    If you are replacing a drive, use this section to find and unplug the IDE/Serial ATA or power cables.If you are adding an additional drive and the empty bay is part of a removable drive cage, use this section to find and unplug the cable to make the drive cage removal easier.If you are adding an additional drive into an empty drive bay on the chassis, skip this section and go to Step 5 .
  1. Find the hard drive. The hard drive usually sits under the CD and DVD drives and has a thin flat ribbon cable.
  2. Disconnect the IDE or Serial ATA cable and the power cable from the back of the drive. remember where each cable goes. IDE Serial ATA c00378000.jpg c00378001.jpg
c00564485.jpg Step 3: Removing the drive cage On many HP and Compaq PCs, drives are attached to drive cages. Often, the installation and removal instruction for the cages are located next to the drive cage or on the side panel. The following images are some examples of the types of drive cages that come on HP and Compaq PCs. For more detailed information information about a particular chassis, refer to the Hardware and Servicing guide or User Guide for your particular model of PC. Drive cage examples c00378002.gif c00378003.gif c00378004.gif c00378005.gif Step 4: Removing the drive
    If the drive is attached to the chassis or drive cage with screws, remove the screws and slide the drive out.If the drive is retained by a plastic latching system, lift the latch to slide the drive out.Set the old drive aside. If the drive is to be re-used, place it in an ESD safe container for storage.
Jun 30, 2010 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
When my i-pod is attached to my computer it works and when it is
You need a new battery then. You can order one online for a reasonable price and installation is fairly easy. I have posted two web sites that sell batteries for iPods as well as step by step instructions for the click wheel iPod models. www.ifixit.com
iPodbatterydepot.com
Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
With the casing separated, grasp the top half (the part with the front bezel) and flip it over. Note that there is an orange cable in the top left corner that connects the iPodlogic board to the headphone ports. If you gently grasp the cable and pull, it will slide out of its connector on the headphone port module board.
Headphone Jack Board Removal Before proceeding, you must remove the top case.There are two t6 screws holding the headphone port in place. Remove both of these screws. You can now remove the headphone module.
Hard Drive Removal Before proceeding, you must remove the top case.Hold the hard drive up, and remove the black tape on the hard drive connector. This will reveal the hard drive cable’s connector to the logic board.To remove the hard drive, grasp the cable (thumb on top index finger onbottom) and gently pull the cable out (away from you and the connector)The hard drive will now be free of the iPod logic board.
Hard Drive Cable Removal Before proceeding, remove the hard drive.To remove the hard drive cable, hold the drive, and gently pull up on the cable.It should come out easily.
Headphone Connector Cable Removal Before proceeding, remove the hard drive.To remove the headphone connector cable, Grasp the cable, and gently pull up. It should come out easily.
Logic Board Removal Before proceeding, remove the hard drive and headphone connector cable First, disconnect the battery connector by grasping the cable and gently pulling up to disconnect the cable from the logic board connector. Remove the 6 black T6 Screws.
With the screws removed slightly move the logic board to the left to give more access to the clickwheel cable. Gently pull this cable to free it from the logic boardconnector.The logic board will now easily come free from the case. The LCD will still be attachedto the logic board.
LCD Removal Before proceeding, first remove:Hard DriveHeadphone Connector CableLogic BoardTo remove the LCD, grasp the green connector cable, and gently pull to free it from the logic board connector. It should come out easily.
Battery Removal Before proceeding, first remove:Hard DriveHeadphone Connector Cable Logic Board To remove the battery, use a flat tool to pry the battery up. It is held on with a lightadhesive, and should come up by using just a little force. Lift the battery out of the unit.
Everything goes back in with gentle pressure and of course replacing screws and what not. All in all though, it is allot cheaper then buying a new iPod or other MP3 player :) I hope this is helpful to you
May 09, 2009 | Philips GoGear SA5285/37 Digital Media...
I would like to upgrade the harddisk in my compaq evo D500.
if you wanna open whole case then:
Turn the notebook upside-down.
* Remove the 3 Torx T-8 screws located towards the front of the computer.
* Turn the notebook right-side-up.
* Lift the LCD to its upright position.
* Carefully lift up the palmrest making sure not to tug on the mouse's ribbon cable and let it rest on the keyboard. WARNING! If you tug on the cable you will disconnect the mouse and it is NOT EASY to reconnect!
* Remove the 4 Torx T-8 screws that mount the hard drive in place.
* Gently lift the hard drive up a few inches and remove the ribbon cable attached to the hard drive.
* Remove the 4 Torx T-8 screws that mount the hard drive to its bracket.
* Remove the hard drive from its bracket.
* Place the new hard drive into the bracket.
* Attach the 4 Torx T-8 screws that were removed in STEP #8.
* Attach the hard drive ribbon cable to your new hard drive.
* Seat the new hard drive into its compartment.
* Replace the 4 Torx T-8 screws that were removed in STEP #6.
* Replace the palmrest, making sure it snaps down into place.
* Lower the LCD.
* Turn the notebook upside-down.
* Replace the 3 Torx T-8 screws that were removed in STEP #2.
if you just wanna open HDD case then just follow selecting above instruction.
And for HDD size.
if depends on your using perpose:
if it's for general use then 80-100 GB is enough if its for graphic or gaming propose then you need to consider more than 200 GB and RAM too.
Thanks and do not forget to rate answers.
Jan 01, 2009 | Compaq Evo D500 PC Desktop
HP Pavilion 9695C PC Desktop Logo
1,610 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
