How do I replace a f-type connector on my t.v.
Broken f-type connector
    Genius:
  • 1,030 Answers
Happens all the time. the way a technician would do it is to remove tuner from unit and if the tuner is not damaged too bad then it can be resolderd back on or a new one put on. Again if the tuner is not damaged which is what happens alot of times when the rf connector is broke off. Let me tell you the most inexpesive way of dealing with this.. feed the signal through another input. eather with a vcr or your cable box.. the rca jacks red white and yellow. then change input on your tv.
Posted on Jan 14, 2008
2002 350 Rancher. It backfires but why won't it run?
Hi, Jennifer and the usual suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Oct 23, 2015 | Honda Motorcycles
Canon 3225problam e00024canon
Developing plug was disconnected / toner sensor disconnected. Find toner capacity for wire detection sensor connection is broken.
See is not developing sensor wire connector loose or broken wire connector.
The code is not clear, after troubleshooting, after power is gone. Try another developer, powder case will substitute the above failures.
Also what is the type of machine?
laptop batteries
Cordless Drill Batteries Replacement Cordless Power Tool Batteries...
Dec 08, 2014 | Office Equipment & Supplies
What type of connector is used for front camera?
Contact t Asus cust service. They will fix it for you.
Apr 26, 2014 | ASUS Open Box - VivoTab TF600T-C1-GR 64GB...
My emachine monitor keep saying no singale
May be a bad pin (bent over or missing) on your monitor cable to the video jack on your computer. If a bent pin, you can straighten it with small needle nose pliers; VERY SLOWLY--fast moves can fracture the pin and break it. If a pin is missing (broken off), the connector must be replaced. If connector looks good, and is not a molded, but a soldered type, a broken solder joint can be repaired, If it is a molded cable, the entire cable must be replaced.
I focused on the cable because this is the most common cause of "no signal", and further troubleshooting would be 'involved', to say the least.
Mar 01, 2013 | Computers & Internet
Removing the keyboard broke the plug
Never have seen a Keyboard's Flat Flex Cable, that had a connector on the motherboard end. http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
The motherboard connector is a type of ZIF connector. Zero Insertion Force. It is composed of TWO pieces, but DOES NOT come completely apart.
The bottom piece is the BODY. The top small piece is the Locking Bar.
IF, the Locking Bar is broken off, you may be looking at MOTHERBOARD REPLACEMENT.
http://www.laptoprepair101.com/laptop/2009/11/17/fix-broken-keyboard-connector-on-laptop-motherboard/
Regards, joecoolvette
Aug 31, 2012 | Acer Aspire One D270-1824 Aod270-26dkk
My power suplly is broken and i cant use my xenyx1002fx. can i order a new one?how mach it cost?
Broken pins are common on these power supplies. The units are hard to find. If yours only has broken pins in the connector, find the connector type and have it replaced. Fifeteen minute job...
They probably use MINI DIN types available from Digikey.com or Mouser.com.
May 30, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How to replace dc power jack for toshiba p15
Take apart laptop and see what type of jack is on your system. There are two types. one is soldered on and the other is a module that connects to the motherboard with a wire connector.
If you have a soldered on type the you will need to de-solder it from the board then solder a new one onto the board. most ac jack issue just need to resolder it unless the jack itself is broken.
May 19, 2010 | Toshiba Satellite P15-S420 Notebook
Broken speaker connectors
Yes you can get relacements, you need to try Maplins or similar type of electronic store. You can also get connectors that will solder on the ends of the speaker wire and will push into the speaker connectors, the common name for these is Banana plugs, this may be a cheaper solution.
Nov 28, 2009 | Cell Phones
Battery charger for craftman electric lawn mower model no 625 connector from charger to battery is broken and need new connector or complete charger
junked the charger connectors and replaced the connectors with better type of connectors that an old man can get a hold of to take apart to connect the charger when needed very poor design for elderly use.
Jun 13, 2009 | Craftsman Garden
After timing chain replaced catalytic convertor light on
recheck wires all back on to sensors,sounds like one is loose or terminal connector block has a broken wire behind the rubber cover
Nov 26, 2008 | 2000 Jaguar S-Type
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
