28 Other Users Have The Same Problem - Continued
Comment by JHBuffaoNY, posted on Jan 19, 2009
I have the same problem as described by all on this thread. I do have the LED version of the 61" TV and it STILL shuts off on it's own. So before you think an upgrade to the newer version will solve the problem think again!
Will be attempting to re-attach the back plates as noted to see if this fixes the problem or helps control it and will follow up with results.
Comment by Guest, posted on Jan 15, 2009
I had 61" Samsung DLP under 4 yr warranty....after 3 attempts by BB techs, 2 bulbs...circuit board replaced...they honored the warranty and gave me a brand new 61" DLP(samsung)....needless to say.....after a couple of weeks..IT happened.....TV shuts off then turns right back on.....doesn't do it every day or even every week but it still does IT!!. Right now I just live with it.....the heat on the lamp makes sense to me.
Ron in Florida
Comment by Guest, posted on Jan 11, 2009
I have talk with Samsung many times. Are there any class action suits pending on their DLP sets.
Thanks
Mike
Comment by broadband100, posted on Dec 23, 2008
50" DLP TV, same problem. We've had it for about 3 uears. 1 1/2 years ago, I replaced the bulb and all was fine. In the past month we noticed it began to shut itself off intermittently. It seems to occur once every few days. We simply turn it back on and it runs ok for the rest of the day.
I am also curious what part the other poster was referring to when they mentioned the repair man replaced something in under a minute which solved the problem.
Comment by Guest, posted on Nov 25, 2008
Our tv is only 18 months old and it shuts off all the time. It is so frustrating that you pay that much for a tv and it doesnt work. We have 2 older tvs that have lasted 5-11 years. We will never ever buy a Samsung again.
Comment by Guest, posted on Aug 30, 2008
Yep happens a couple times a day..not to mention have to spring for a lamp every year.
Comment by Guest, posted on Aug 19, 2008
TV shuts off intermittently the light cover has never been off so I doubt it is the switch behind the light cover.
Comment by cindyj49, posted on Aug 15, 2008
I have the same problem with a 56"DLP. I have tried all of the offered solutions to no avail. The company I bought a 3 year extended warranty from went out of business so I am really trying to find a solution without calling a repairman, since it seems like there is no one easy answer. I think Samsung needs a class action lawsuit regarding these DLP TV's. It is amazing how many people have problems.
Comment by Guest, posted on Mar 26, 2008
My 50 inch DLP shuts off by itself, sometimes several times over a period of 10 minutes. After it shuts off, the "Lamp" LED blinks for about 10 seconds.
Comment by Guest, posted on Mar 04, 2008
I just had a visit from a tv repairman for the same problem. He said the DLP TV's have a problem with the light engine needing to be replaced and that he has probably replaced over 50 of them. He said they used to replace just the light, then another part, and the TV would be okay for a few weeks then act up so they replace the light engine from the start of this problem now. Luckily it is under extended warranty as he said it costs $750 to $800 to replace. Best to have extended warranty on these TV's.
Comment by SAMESONG, posted on Mar 04, 2008
I am having the same problem with my Samsung DLP TV Model# HL-R5667W. The TV picture will go black for a few seconds while the sound continues and then it shuts off. It has been happening more ofter ( every 5 minutes) for the last 2 weeks. I thought that the TV might be overheating and needed a new fan since the light on the power button read "STAND BY TEMP" when it turns off.
I chatted with Samsung technical person on-line and they had me make sure that the vent at the rear of the TV was not blocked, which it wasn't. I asked what symptoms occur when you you have a malfctioning fan and he said that I would hear a buzzing noise, which I don't.
Does anybody have any ideas before I dish out $250 dollars just for a technician to come out and guess to what the problem is....at my expense.
Comment by rperez, posted on Mar 03, 2008
In September I had a technician come out and replace the bulb on my Samsung 50" dlp proj tv. Two weeks later I had to have him come back out because the tv would shut off by itself. This too would sometimes happen every 10 minutes and then sometimes it would go a few hours without happening. I was told that it was the main engine of the TV and they ordered all of the parts. In December my tv was replaced under the warranty since the part was on back order for over 45 days. What is crazy is I got the new tv and then the first week of February UPS delivers the assy engine and core charge parts for the tv I no longer have!! I made 3 phone calls to have the parts picked up and got no where. So now I have a new tv and parts for the old tv with the problem. It seems as soon as you have bulb service on these tv's then this shut off problem starts to happen.
Comment by 99vfr, posted on Feb 27, 2008
I also have the same problem, only my TV is HLN467WX The TV will just go black but there is still sound, or the picture will freeze in this reverse negative frozen image. You have to turn it off then back on. Lately it's been occuring 10-15 times an evening.
Any ideas?
Comment by tsara, posted on Feb 27, 2008
I have the exact same problem.... started about 2 weeks ago. 8 month old Samsung DLP... it just shuts down... sometimes 3 times every 5 minutes.
Have no idea what to do.
Comment by Bill in FL, posted on Feb 25, 2008
Same problem my Samsung hlp6163W has an intermittant shut off problem. Please send me your repair ideas.
Comment by guest8021, posted on Feb 23, 2008
I also have the same problem, not only with the intermittent shutting off, but also the picture issues in the dark environment as the previous poster. I just had my HDMI slot fixed on Wednesday and afterwards it started happening. Also, the colors in my picture seem a lot brighter then they were before, despite having all the same picture/color settings. I have a Samsung DLP HLR5667W.
Comment by Guest, posted on Feb 20, 2008
We are having the exact same problem as well as we are seeing almost blurred figures when there are scenes in a dark environment. A repair person will be visiting us on Monday.
Comment by Guest, posted on Feb 19, 2008
yes , have exactly the same problem. illinois
Comment by leandrosgf, posted on Feb 17, 2008
Hi, I have a DLP SP-50L3HR ( similar model 50' in Brazil ) and I'm facing the same problem. I saw from jod400 that there are a small part that we can replace to solve this problem. Here in my country the Samsung service is requesting around US$ 400 of pre-approved budget to see what is wrong!!
Jod400, do you know what is the part that you replaced in your TV? I'll ask here to check if I have a similar one and try to replace it.
Thanks in advance
Comment by Guest, posted on Feb 13, 2008
I have the same exact problem This is ridiculous, Samsung played dumb when I called inquiring about the problem. They said they haven't had many complaints. Hard to believe after reading all of the complaints on the internet.
Comment by Guest, posted on Feb 09, 2008
Mine just started doing the same...intermittant shut off. Never know when or how many times its going to happen. The tv used to make a sound when starting up...kind of a blip sound. I noticed it doesnt do that anymore. It just shuts off and as many as 5-6 times within the first 20 minutes of viewing.
Comment by Farmer Ben, posted on Feb 06, 2008
I have 61 inch DLP and it does the same thing. Some days it works fine and then it will just click off. Some days it does it 5-10 times then it may go 2-3 days just fine. I do notice it has a loud popping sound occassionaly, like it gets too hot......
Love the TV, but it sure is a pain...Every part including the color engine has been replaced to no avail....
Comment by jod400, posted on Jan 14, 2008
I've had my Samsung DLP TV for 6 months. It just started to shut off on its own. It can go a week without a problem and then it will shut off after being on for a few minutes. After a few auto shut offs, it works fine for the rest of the day.
