Maytag mah4000 washer
Washer will not empty water out of basket on final phase of cycle .
  • 1 more comment
  • Anonymous Nov 09, 2008
    wator won't pump out
  • Anonymous Mar 22, 2009
    Water will not spin out of basket.
  • Anonymous May 08, 2009
    water is not draining.  sounds like it's running throuh a full cycle but when finished there are wet clothes under water that are no where near spun dry.
My machine (Maytag MAH4000aww) failed to drain because of a bobby-pin that was lodged in the drain pump impeller. Because of the added weight of the wet clothes, and the undrained water; the machine would not spin. The Wax motor worked as the door did lock properly, but the machine would "ramp up" trying to spin, but would stop the process when it sensed that the load was grossly unbalanced. Check the drain pump to see that it is not clogged or that the impeller is not impeded by a foreign object before spending money on imbalance switches! I will now cancel the service man, who surely would have charged me for a new pump, plus the cost of the visit, and now I can stop swearing! My wife is glad she married me!!!!
Rene Marchand (Beaumont Alberta)
Posted on May 03, 2008
Thank you BanjoBoy, My wife washes an old bathroom rug with the rubber backing. The rubber was harden and broke into small pieces which clogged the drain. After I cleaned the drain pipe underneath the tub, the washer works like a charm!
Posted on Nov 07, 2008
    Scholar:
  • 196 Answers
The main control board is not sending a signal. Only solution is to replace the board located in the control panel. The MAH4000 series is notorious for board failure.
Posted on Jan 14, 2008
6ya staff
SOURCE:
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
LG Tromm WM2277 leaking from back bottom
The last spin is the final Emptying phase. There has to be a leak somewhere in the exiting water route. All tubing and the water pump along with all clamps will need to be checked for integrity.
Poppa
http://www.cdbaby.com/cd/poppamadison
Aug 04, 2012 | LG WM2277H Front Load Washer
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Mah4000 maytag how to locate remove and clean
if you think your problem is a dirty sump run a good quality appliance cleaner trough it first much easier than stripping down machine give it a go
Nov 04, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Old machine; model A511. wash cycle won't
Should be worth fixing. Belt kits for Maytag A511 washers are still available on line (about $30).
Jul 08, 2009 | Washing Machines
Washer makes loud, thumping noises during spin cycle.
support bracket that supports the tub is breaking. stick your hand inside and push up and down and see if its coming apart. if u look at it when it runs does it wobble?(the tub) if not take a look at the pulley on the back and see if its wobbly.
Jun 22, 2009 | Washing Machines
Mold and smell from Maytag washer
The mold will be growing in the upper parts of the agitator basket above the water line. Spray these areas with a bleach/water mixture using a spray bottle. Turn off the hot water valve to your washer. Disconnect the hose connected to this valve. Connect a leak free garden hose to the valve. Connect a garden sprayer to the other end of the garden hose. Turn the hot water valve back on. Check for leaks. Use the garden sprayer to rinse and remove the mold. Be careful to keep all of the water in the agitator basket. Turn off the hot water valve. Reconnect the hose from the washer to this valve. Turn the hot water valve back on. Check for leaks. Run a wash cycle with an empty load.
Jan 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune MAH4000
Are you getting cold water to fill ?How is the water pressure?Timer maybe at fault here.
Jun 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
403 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
