Question about Dell Dimension 4600 PC Desktop
Power problem I have a dell dimension 4600 desktop and the tower will not power on. I have tried switching the power cord and thats not the problem, plugged it in a another outlet and still nothing. I'm not sure if the power button could be broke as it does not seem broke. Also, I have noticed after taking off the cover, that it has a green lit light on the circuit board so I guess thats good? Why wont my tower power?
  • angelface01 Jan 13, 2008
    thank you for your help.
  • Debo136sst Sep 17, 2008
    I have a Dell 4600 PC Desktop that recently wouldnt power on in the tower. It took a day or two before it worked, by me just touching the mouse it all of a sudden powered back up. Worked continuiously for the next 3 or 4 days. On and off wth no problem. I evene checked and ran scans for viruses. But last night I stupidly added Limewire back to my computer and today I tried turning the tower back on today and it had the same issue of not powering on.Is my Power Supply going bad? And if I need a Power supply how much would one cost. Is there any way that my limewire could be effecting my towers power, since I just put the program back last night now all of a sudden it doesnt work again after recenlty deleting it and most viruses? It seemed to have worked great last night . Im thinking probably Limewire or my Power Supply is the cause. Anyone know any tricks to get it running just one more time so I can dlete Limewire and see if thats the case?
    President:
  • 317 Answers
    Sergeant:
  • 263 Answers
Check for unplug wire coming from the front panel if there is nothing unplug you may have to change your power supply or if you have a power supply tester check it first if not i'm kind of sure the problem is your power supply rate me
Posted on Jan 13, 2008
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
I have a Dell Dimension 4600. I press the power button. The left light on the tower turns on amber, the right light comes on for 15 seconds or so then shuts off. The monitor will not come on, but will...
The most likely cause is a failing power supply. Unless you have a tester you will need to buy a replacement. Check the specs and order a suitable replacement. (www.newegg.com is my choice)
If any of this goes past your computer knowledge take your computer to an expert to examine first-hand.
Dec 26, 2010 | Dell Dimension 4600 PC Desktop
How do I get the cover off of my Dell Dimension 4600 Computer. The position of the lever is not obvious.
press the lever catch on the back of the tower DOWN, and hold it and slide the side panel to the rear
Sep 17, 2010 | Dell Dimension 4600 PC Desktop
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
I have a dell dimension desktop. It won't turn
open the tower//
check for any loose connection of the cord of Hard drive and power unit//
better option is take out the wires one-by-one and refix it//
if this does not work then probably the SMPS has gone bad and needs to be replaced..SMPS is the power unit which supplies power to all the component.
during all this process please alwaws make sure that when you put ur hand in the tower then the power cord should be out , otherwise you can get power shock.
May 15, 2010 | Dell Dimension E510 PC Desktop
When I start the Dell Dimension 4600, it says "Enter password." But when I type the password, the cursor won't move, and no asterisks appear for each character of the password. After repeated attempts, the...
First thing I would do is to reset your CMOS by:
1) Power down.
2) Remove power cord.
3) Push power button in and hold for 15 seconds.
4) Open the case.
5) ground you self to the case for a second. (touch bare metal)
6) Remove the battery for 30 seconds.
7) Replace battery.
8) Double check all your connections and cards if any.
9) Close the case.
10) Connect power and power up.
Your diagnostic lights indicate "Other Failure". (The one on the right is amber, correct?) That could be anything. Here is a reference for your diagnostic lights:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm#1112886
Try resetting the CMOS first and comment back.
BTW, this will remove your password too, so you will have to go into the BIOS and reset. You will probably get a "Configuration change" message when you first boot up. Press F1 to go in and then do a Save & Exit.
Thanks for using Fixya.
Dec 12, 2009 | Dell Dimension 4600 PC Desktop
How to soft boot a dell 4600
I used the reset button on my last one whenever ctrl/alt/del failed to soft boot
my computer.
Here is what Dell Chat tells me to do if ctrl/alt/del doesn't work:
Turn off the system from the power button. Remove the plug to the
power supply from the back off the system tower.Then hold the power
button on the tower down for 10 secs ( with the power cord removed).
Reconnect the power cord and then restart the system.This time do a
normal shutdown.
Regards,
Pp
Dec 02, 2009 | Dell Dimension 4600 PC Desktop
After sitting idle for 24 days my Dell 4600 PC doesn't power up
Take your machine to your local computer repair shop for daignostics.
Good Luck.
Mar 04, 2009 | Dell Dimension 4600 PC Desktop
Dell 4600 Dimension Computer
are you getting the DELL logo screen.
Jul 04, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
105 people viewed this question
Alun Cox
