Question about Honeywell HUT-102 1.2 Gallon Humidifier
Honeywell Humidifier HUT102m
I don't know how to fill this humidifier the water runs straith through it I lost the instructions the web site does not have the instructions available
  • Anonymous Jan 20, 2008
    I'm having the same problem... no instructions came with my humidifier and there is nothing online to help. I don't know where the demineralization cartridge goes or how to fill the tank.
  • rocksey42 Jan 21, 2008
    I have figured out how to fill this thing. Turn the cap where the thing that you push to let the water in takes no time at all
    Problem Solver:
  • 6 Answers
I've been having problems with this unit since purchase in December 2007.
To fill, unscrew the cap with the spring loaded plunger. It may be tight, but it has two slots which you can turn like a screwhead using something wide enough (eg, a spoon) for leverage.
My problem is that this thing leaks badly. The fit of the cartridge is terribly designed. The one supplied is different from the one depicted in the unhelpful manual, which is silent on where the cartridge should fit. It will fit in one spot, but it will not sit flush with floor of the unit; it rocks and the water holding top rocks with it. The supplied cartridge appears to be an attempted and unsuccessful fix of a problematic design.
Even without the cartridge, this unit still leaks.
A web search shows others complaining about leaking. Hate to say it, but another example of lousy American design... but it sure is pretty!
Haven't been able to raise the manufacturer "Kaz" on the phone.
Posted on Jan 26, 2008
Its the worst design to fill it up that you could imagine. i was lost for a 1/2 hr trying to figure it out. well that 'easy to fill' feature on it means that you have to flip it upside down, balance it on its awkward shaped top, press in that spring loaded piece on the underside with one hand, and fill it (takes forever) with your other free hand in the same spot (apparently it opens up a valve that allows water in).
Posted on Jan 21, 2008
Why does it make a constant hissing sound?
The fill valve inside the humidifier is leaking. This is a common failure as the valve clogs with mineral content from the water.
Jan 28, 2016 | Honeywell he225h8908 bypass humidifier,12...
A/C won't come on, replaced batteries, display reads -AC Honeywell chronotherm III Thanks for any advice !!!
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 07, 2010 | Honeywell Power Humidifier: Furnace...
Our HCM-640bw Honeywell humidifier will leak water onto the floor. If I fill the tank and let it sit without turning it on, no leaking. When it runs for about two hours it leaks bad. Any ideas on how to...
Found a hairline crack in the water canister. Had to locate by filling the canister and waiting for a couple of minutes for water droplets to form outside the canister. This ever so slight crack allowed air to enter the chamber and made changes to water dispensing rate which overfilled the resevoir over time ( hours). The cracks were not visible under 10X magnification without the water droplets.
Jan 18, 2010 | Honeywell QuietCare HCM-630 Humidifier
Honeywell Natural Warm Moisture Humidifier Is On But No Steam?
I have the same problem and I have 2 of them fairly new. I can't seem to find out what the problem is either.
Stumped?????????
Apr 10, 2009 | Honeywell Humidifiers
My HE260A is discharging too much water
these are flow thru models and a lot of water passes thru them. The instructions say to not limit the water by closing valve at all!
Feb 22, 2009 | Honeywell HE220A1019 Whole House...
Honeywell HE220A water not reaching humidifier
Replace the Valve on the unit. Check the small filter inside of it where the waterline attaches first. If its clear and you have lots of flow from the 1/4" line the replace the valve.
Jan 19, 2009 | Honeywell HE220A1019 Whole House...
Cleaning water tray
I usually just balance the tray upside down on top of the base and fill the edges with vinegar. You could also put the the tray in a bowl filled with vinegar and submerge the whole thing.
Dec 19, 2008 | Honeywell HWM-450 4 Gallon Humidifier
Honeywell 360a humidifier
yes water should turn off solinoid is bad
Oct 24, 2008 | Honeywell HE360A1027 Whole House...
Continous ware flow on Honeywell HE220A Humidifier
I am having the same problem. I have had my humidifier for about 5 years now and I just started having the problem where the water continuously flows through the solenoid. I took apart the solenoid by removing the fittings from both sides. When I did that, I noticed that there was a hole in the metal that allowed me to see through to the other side. Apparently, it had corroded and and broken through, allowing the water to pass through the solenoid without really going through the valve within the solenoid. There are several sites that sell replacements for about $70, which is not cheap, but cheaper than buing a new humidifier for $120. Here is one site I found: http://www.iaqsource.com/product.php/honeywell/32001639-002/?product=112783&category=1142
Oct 18, 2008 | Honeywell HE220A1019 Whole House...
Honeywell HUT-102 1.2 Gallon Humidifier Logo
407 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
