Question about Sanyo VWM-950 VHS VCR
Playback During playback my vcr just shuts itself off after about 10 seconds. Then when I turn it back on it ejects the tape.
  • swwajenn Jan 16, 2008
    Thank you very much!
  • 579 Answers
Just the usual problem of needing the rubber belts replaced.
The VCR's has a sensor that monitors if the take up reel is turning. If it doesn't turn for a few seconds then it shuts down. The most common problem is the idler tire (or clutch) starts slipping too much abd the take up reel doesn't have the strength to pull the tape back into the cassette.
Buy a kit of belts for your model from all kinds of sites on the net and install them yourself if you are handy with delicate mechanisms.
Hope ya fix it!
Posted on Jan 15, 2008
Machine suddenly shuts off during playback or record - is this fixable?
When something goes wrong during playback etc, all VCR's will shut down to prevent tape damage, or further mechanical damage.
There are two possible causes for this problem. One is there is some sort of damage to the mechanism, possible a plastic part that is broken. The second cause is the mode switch. This tells the electronics what position the mechanism is in. If that goes wrong the electronics might think it is in eject mode when it's in playback, for example, with things going very wrongs as a result. All are fixable if you can get the parts!
May 02, 2016 | Toshiba Televison & Video
Unit will not stay on. Turn power on unit with no tape. After several seconds cycles off. I am using the aux. to monitor a cctv camera.
VCR's with faulty mechanisms will power down to prevent tape damage. Checking inside might reveal damage to the tape mechanism. Even if the mechanism isn't damaged the VCR has a device called the mode switch. These tell the electronics what position the mechanism is in. If that goes faulty the electronics can think that mechanism is in say playback mode, even when it's in eject mode. So when it detects no tape tries to stop and eject the tape. Since it can't carry out this it shuts the entire video down to be on the safe side and prevent further damage.
Mar 15, 2015 | Emerson EWV404 VCR
Vcr ejects after 10 seconds
The tape is wound tight or is not wound evenly creating friction. There is a safety feature designed into the vcr that senses that there is too much tension. Fast forward all the way then rewind all the way. This is the way it was in the 70's 80's for cassette tapes and vhs tapes. If the tape still ejects then check the belts.
Dec 01, 2013 | Toshiba DVR620 DVD Recorder/VCR
If you mean that when the recorder is paused during recording or playback, then it shuts down after being left awhile. Then I'm afraid the asnswer must be no.
The reason is because it's the recorder protecting itself and the tape from risk of damage. As when the tape is laced up, the head spinning at high speed can cause static electricity, plus the general risk that the tape might get entangled. The timer is all part of the micro controller in any case, which is the "brains" of the VCR.
However if the VCR is shutting itself eratic, then there's some kind of fault.
Jul 05, 2010 | Mitsubishi HS-U449 VHS VCR
Canon hi-8 camcorder will not playback recordings. full battery. ejects tape during playback
It sounds like the tape isn't turning and the player thinks it's to the end of the tape and ejecting it.Perhaps when you rewind its drawing the tape up so tight the sensor thinks it's at the end.Take the tape out and see if you can turn it by hand to release the tension.There's got to be some form of release mechanism to let the tape free wheel.Once loose I'll bet it will playback just fine.
Jan 18, 2010 | Cameras
Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Jan 29, 2009 | Panasonic AG-7350 VHS/S-VHS playback VCR
SONY VCR: Keeps ejecting video tape
may be machnical stuck in playback mode. remove the cover and see the loading arms are near the video head , if not try to release the arm rotating caption wheel smmothly . don't push more force to rotate the wheel.
Jul 11, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Another possibility is that the tape is caught aroung the spindle guides that pull the tape around the video head. If the tape is caught in the spindles, this will affect playback performance. The heads could be dirty too. Another possibility for poor playback is a slipping idler wheel. The idler wheel is a rubber tire that pivits between the tape sending and pickup reels. It's a key part during playback, fast forward & rewind. The idler tire can also be treated with a re-grip solution or be replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor.
Jan 09, 2008 | Panasonic AG-1330 VHS VCR
That's dirty video head! Try to playback new tape for five minutes, do it for 2 to 3 times, this will serve as your videohead cleaner. eject then reinsert then playback, eject again for at least 3 to five times. most camera has a built in videohead cleaner that activates during eject, initial play and reinsert mode. you can even try to play the whole blank tape! thats 1 to 2 hours of playback! If the problem is still there after doing those things, you need pro fix then.
Sep 13, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Toshiba M-752 Video Casette Recorder
Take the top cover off, and see if there is an obvious reason for the no-eject, as in tape spooled out and wrapped around something. Next, is the tape drawn back into the tape housing? Under normal operation this is done before eject. A defect in the tape itself, or in the VCR mechanicals can cause a no "pull in" condition. Otherwise, you could carefully try to assist an eject- push eject, lift lightly on the tape. Sometimes the entire carriage mechanism can be removed with tape in place, but often, screws holding this in place are obscured by the tape, and, if carriage is gear driven, proper gear alignment must be reestablished. This can be a tricky problem, getting tape out without damaging anything, especially since late VCRs are made rather fragile to start with.
Aug 14, 2007 | Toshiba W522 VHS VCR
Sanyo VWM-950 VHS VCR Logo
227 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
