Decalcify with 1/3 cup white vinegar and 2/3 cups water. Turn on your machine and let it brew the mixture through the entire cycle. When cycle is complete empty the pot and fill the reserve with fresh cold water and cycle once more. This should clean your unit and if it doesn't do as good a job as you want then complete the entire process once more.
Info per my user manual on my different brand coffeemaker.
Coffeediva22
Was this helpful?
Yes
No
Popular Solutions for Braun Aromaster KF 400 Coffee
i pushed the rubber in the water container (the small black rubber that sticks out from the little...
(More)
i pushed the rubber in the water container (the small black rubber that sticks out from the little tiny hole) and now when i put the machine on the coffee doesnt get despensed into the coffee jar and there is a loud noise coming from the machine.
The coffee maker started to make coffee. It made approximately 1/4 pot and quit. The water was in...
(More)
The coffee maker started to make coffee. It made approximately 1/4 pot and quit. The water was in the tank, the light was on and the 1/4 pot of coffee was hot but it would not make any more. Tried it again with another full tank of water and it will not let any water flow into the coffee making unit. can you help?
The coffee maker's power light comes on, but it won't make coffee or heat the burner. I did find...
(More)
The coffee maker's power light comes on, but it won't make coffee or heat the burner. I did find later that the stove wasn't working, where the coffee maker was plugged in, and found that one of the cartridge fuses for the stove had blown. When that was changed the stove worked, but the coffee maker still did not. I love my Braun and have only had it for about a year. So, it shouldn't be junk already. Help?
