Question about 3Com OfficeConnect Wireless (3crwps10075-us) Print Server
3 com 3crwps10075
I've been trying for days to setup this printserver using the setup wizard from it's website but the printserver is not detected by the wizard.i have connected it to my router but it is not detected by my router. what seems to be the problem? i didn't have this problem when i installed my WPSM54G
Don't know if you have fixed the problem, but one solution is to turn off the Windows Firewall.
Posted on May 11, 2008
  • Trond Hus? May 11, 2008
    Also: After - if you did get to connect to the print server - turn it on and off (unplug, replug) and you might get it connected wireless. I did.
    Best of luck.
My printerserver doesn't show up on my network (working properly). I am using Windows 7 ultimate, Thomson TG585 router, NC-2100p, Brother 1030 (installed as 1430).
hi marc,
good day!
You can power off the Router and Printserver..then test the printserver if still detected on computer,direct testing on computer first..then if it is good,check your network if running good and have an IP addresses..check the IP of printserver too..name it as you like.
mastergani
Jan 08, 2011 | Brother NC 2100P (NC-2100P) Print Server
Printers are not recognized as online by printserver
Have you check which port your PC trying to register your printer to?
Sep 22, 2007 | D-Link DPR1260 Rangebooster G...
Setup stops at printserver will connect to your wireless network
hi
thank you for using Fxiya
go to folowing link you will find complet stup for Linksys printserver
http://www.ehow.com/how_5396340_set-vista-vista-windows-linux.html
May 15, 2010 | Linksys WPSM54G Print Server
Print server for vista, D-link DI-704p
I can recomend to your network setup is WPS54GU2
Wireless-G PrintServer for USB 2.0
******************************** Before configuring the wireless settings of the printserver, make sure to know the following settings on your D-link router: SSID, and wireless security.
Configuring the Wireless Settings on the Printserver
The wireless settings of the printserver can be configured using its web-based utility. Make sure the printserver is set to a static IP on the network.
NOTE: Make sure the printserver is already working when hardwired to the Dlink router before attempting to use it wirelessly on your network.
Step 1:
Access the printserver’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the printserver's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the printserver setup page appears, click Wireless.
Aug 01, 2009 | D-Link DI-704P Router
Failed response from plugin device
Dirty fix...
When the printer errors out...stop, unplug the power to the printserver. Reset the printer, Clear the print que (delete jobs/restart print spooling service), restart the printserver software and plug the printserver power back in. Wait for the re-detect. Everthing should be good at this point. Unfortunatly the print job will be lost and you need to print again...BUT, NO REBOOT yea!!!
Note... for me, if this sequence is not followed, I will have to reboot. The printserver will be locked for the PC that was trying to print. All other PC's will be fine, and I have no idea why.
Good luck,
Bill
Jun 24, 2009 | Zonet MULTI FUNCTN USB 2.0 PRNT SRVR...
My linksys srx200 doesnt seem to be responding to my laptop when
Try to reconfigure the printserver using the setup CD that came with it. Normally that will fix the problem. Make sure the driver of your Printer is installed first before running the printserver setup.
Jun 13, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
My printservers setup wizard utilities will not install model number psus4
This link will take you to the linksys website.
http://www.linksys.com/servlet/Satellite?childpagename=US%2FLayout&packedargs=c%3DL_Product_C2%26cid%3D1115416837650&pagename=Linksys%2FCommon%2FVisitorWrapper
Down load the driver and read the user guide and quick install guide.
Your computer needs the driver in order to recognize the device
Aug 01, 2008 | Office Equipment & Supplies
Upgrade failure
The software that came with the WPS54G model is not (yet)compatible with Vista systems. This model is not listed on the Vista-ready devices from Linksys' website (www.linksys.com/vista). The behavior more likely a result of a software incompatibility.
For PrintServer network setup, you may still use the CD on a non-Vista system (XP, Win2000 or lower). Or, by installing it manually by accessing it's web interface.
To make your Vista working with the printserver WITHOUT the use of the PrintServer CD, do the ff:
1. Make sure PrintServer is configured on the network with the same wireless settings of your router and with a manually assigned IP address which is in range of the router's IP segment.
2. Make sure that computer can print locally to the printer (e.g. via USB connection to the printer).
3. When computer can surf the net and connected to the router's network (wired or wireless), follow the steps from this article and make sure Printer is showing up as Online.
Jul 07, 2008 | Linksys Wireless-G WPS54G Print Server
Installation wizard does not locate the WPSM54G
hello!
what is the model number of your printer? if your setup cd is not detecting your printserver, try the ff:
-- while pc and printserver connected to the router and your printserver connected to your printer. try to reset the printserver for 30sec. Is it printing? If yes, do you see any IP address on the print out
-- If no, unplug the power for 5 seconds and plug the power back in of the printserver then try again to run the setup cd. you may also check your routers dhcp server table if its detecting the printserver
-- if printserver still not detected ty to connect printserver directly to your computer
-- search if you have bi admin utility on your setup cd and install it on your pc
-- manually assign static ip address on the printserver using the bi admin utility and on the pc
-- if successful, connect printserver and pc back to the router and check if you can ping the ip address of your printserver
May 01, 2008 | Linksys WPSM54G Print Server
3Com OfficeConnect Wireless (3crwps10075-us) Print Server Logo
472 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
