Question about KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher
Won't drain - drain light flashing
The rinse only and drain light are flashing and there is about 2inches of soapy water in the tub. I cleaned out the drain hose going to the disposal and it still won't drain. Is there something else I can take apart to clean?
  • 126 Answers
Take drain hose off ,put end in pail, then try pump out.
if it doesnt drain check your pump
Posted on Jan 13, 2008
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Will not clear soap from machine, have to rinse multiple times
are you using regular dish-washing detergent....not liquid dish detergent like dawn....dawn and the like suds up tremendously....regular detergent is manufactured so it will not suds up.
does it drain completely? sometimes a blocked drain will keep enough soapy water in the basin that when the rinse cycle comes on it essentially throws soapy water back on the clean dishes.
hope this helps
Jan 21, 2010 | Haier ESD210 / ESD211 Built-in Dishwasher
Dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
May 30, 2009 | Westinghouse 24 in. MDB421 RF Built-in...
Soapy water standing in bottom not rinsing soap off dishes
It sounds as if it is not draining. Try to trace the drain line under the sink. Usually it goes into a disposall. The port where it connects to the disposall may be clogged. Another thought. If you had the disposall replaced recently they may not have taken the knock out plug out which would give the drain water no where to go.
Apr 09, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher Logo
242 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
