My new Acer flat-screen monitor dispays stretched hortzontal image. I can figure out how to set the correct resolution.
    Novelist:
  • 139 Answers
Right-click on your computer screen...then click on Properties in the pop-up menu. You should see the "Display Properties" window. Now click on the Settings tab and you'll be able to try a different resolution setting.
Posted on Jan 13, 2008
ASUS P4SP-MX detect the new LCD monitor VH197D as an CRT. picture is stretched; circle's becoming a ellipse. Can you help me!?
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Feb 21, 2012 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Re ACER V203H 20" monitor - appearance. Why is the image size only 16" with black margins approx 2" on left and righthand sides? I bought this monitor brandnew - thought it was widescreen. If I change...
It is definetly a widescreen the issue is either with your display card or your resolution setting you need to check both. If you would have told me wether your display is through mother board or scsi card the model of mother board or the display card then i could fix the issue easilly.
Mar 06, 2010 | Acer V203HA Monitor
Screen is stretched widescreen, cannot figure out how to alter the format
You need to set your PC Video resolution to 1366 x 768 for the native resolution of this monitor.
Jan 25, 2010 | Acer X163WB Monitor
22'' LCD monitor aspect ratio is off.
Set resolution to the native 1680 x 1050. Then, using the buttons on the monitor, go into the monitor's menu. go down to "Image Setting", go to "HDMI Mode", then select "PC Mode". This should help everything fit on screen correctly.
Mar 17, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Acer P193W monitor stretched image
What service pack of windows xp are you running? Also, do you have your old monitor, if so, then plug it in and see if the same problem occurs. If not , go under the settings for your graphics card (not windows display options) and see if there can be a correction made to the settings for your monitor. Also, try going to microsoft.com and updating your computer (it's free) and you'll probably get the required driver to fix the problem from them. Check under your control panel and see if you have automatic updates turned on, if so you may want to limit what updates are to be installed by allowing updates but you choose which one's to install. Hope I could help. My e-mail
tallcoolone@yahoo.com .
Jan 04, 2009 | Acer X193W LCD Monitor
Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Sep 09, 2008 | Acer AL2216WBD LCD Monitor
2 problems: 1. Is there a way to make the images on my 19 inch acer lcd monitor not appear stretched? 2. How do I get a screen resolution of 1440 x 900 (It's not one of the options in my display...
1. The only way to avoid stretching of images is by increasing the resolution. Many 19-inch monitors with conventional (4:3) aspect ratios have 1600 x 1200 pixel resolution. The 1600 x 1200 resolution is ideal for graphic artists and those who work with photos, since it's close to the resolution of a 2-megapixel digital photo.
2. You can double check by going to the display properties - Settings- Advanced tab below the screen resolution slider, choosing the Adapter tab, click List all modes and that will settle it once and for all. If 1440 x 990 isn't listed you're likely going to have to buy a graphics card that can reproduce that resolution.
Also try and update the driver for your graphics card.
Jul 06, 2008 | Acer Computers & Internet
Distorted screen
Youre problem is because when a widescreen monitor is fed with a signal that is not ws it stretches the image sideways making people look short and fat. The only way to really fix this is to make sure the graphics card is providing a widescreen resolution to the monitor. In this case the native resolution (the resolution the screen looks best at) is 1680 x 1050 . If you right click ur desktop and go down to properties and settings u want to change the screen resolution to a widescreen res.
Hopefully 1680 x 1050 ... if this is unavailable try 1440 x 900
If you have an nvidia graphics card you can also go to the nvidia control panel and change the resolution attributes. If the widescreen res isnt available u could also try the 'change flat panel scaling' and select the do not scale option.
Please note before starting any of this make sure u have the latest graphics and monitor drivers available.
May 27, 2008 | Acer AL2016W 20" LCD Monitor
How do I get the widescreen monitor to show unstretched images?
i had the same problem with my new widescreen monitor... turns out the best setting (at least, for my specific monitor) was 1440 by 900 pixels. at this setting the desktop still stretches itself to fill the entire screen, but everything else is completely unstretched. (to adjust the screen resolution, right click anywhere on the desktop, then go to properties, then settings.)
Nov 07, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
