Question about Fisher Paykel EcoSmart GWL15
The lid will not lock.
The lid won't lock to the washer so I cannot start the washer. I called the toll free number for assistance and did not receive any help. The lid locked button is flashing and beeping five or six times at a time. I tried pushing the slot with a screwdriver where the lid locks, but nothing happened.
  • 2 more comments
  • Anonymous Mar 22, 2014
    push start button nothing happens
  • Anonymous Mar 24, 2014
    Washer stays in pause
  • Anonymous Mar 27, 2014
    lid locks then unlocks
  • Anonymous Mar 30, 2014
    no lights no start
    President:
  • Fisher Master
  • 2,651 Answers
You cant bypass this switch by pushing w/ screwdriver. its a magnetic reed switch open the top deck (3 screws behind the console) inside should be a tech ref sheet quite helpful trouble shoooter in ther
Posted on Feb 22, 2008
6ya staff
SOURCE:
TO CREAT MY NSFAS ACCOUNT
Contact NSFAS for assistance.
FIXYA is not a university or government institution.
Call or email on use online NSFAS information.
Once a student has applied to NSFAS, a maximum waiting period before getting a notice of acknowledgement is a week. Should a student not receive the acknowledgement, they are requested to call NSFAS's TOLL FREE Call centre, which is 08000 NSFAS (67327)
https://twitter.com/mynsfas?lang=en
https://meanstest.nsfas.org.za/nsfas/passwordReset.html
http://www.nsfas.org.za/content/
Call local number 0860 067 327 or toll free:
0800 203 900
or email:
[email protected]
http://www.nsfas.org.za/content/studentsupport.html
08:30 - 17:00 (Monday - Friday)
08:30 - 16:30 (Saturdays)
Sep 27, 2018 | Higher Education (University)
I have applied and submitted the application form but when i submit it they say they have my information on their system but i never applied before and i do not have a student number to upload
Call the NSFAS phone number to ask for assistance.
You can also email on use online NSFAS web site for information.
0800 203 900
or email:
[email protected]
Sep 13, 2018 | The Computers & Internet
Clear memory for second user on blood pressure monitor
Try pressing the start stop buttons at the same time. If this is not correct you can call toll free for tech assistance, here is the number:Toll Free Help Line: 1-800-568-4147
Aug 15, 2016 | Microlife Health & Beauty
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Sep 28, 2012 | Washing Machines
Locking mechanism
replace the lid lock ! its a safety measure. I would not recommend removing or bypassing lid lock. just replace it. without the lid lock it will work with lid open. good-day ! if you really what to bypass the lid lock. Find the wire that goes to the switch. Splice the wires together and the machine will think the lid is shut all the time. if you can not get top of washer off. just call an appliance center and give them the model and serial number. and they should be able to tell you. good-day !
Dec 13, 2011 | Kenmore Washing Machines
D L light comes on and washer will not start,lid will not lock.
'dL' does stand for 'door Lock (error)' confirming that there is a problem either with the lid lock (probably) or the lid locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 14, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't spin
If a washer will agitate and wont spin check the lid switch. Lid switches are designed to not allow spin on most washer but will allow agitate. Safety feature.
If you need further assistance please feel free to comment me back.
Jul 27, 2011 | GE WBSR3140DW Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
896 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
