Question about EliteGroup NFORCE4-A939 (NFORCE4A93910) Motherboard
Hi...I have a NFORCE4-A939 motherbooard. I have 4 hard disk drives installed.....3 of which are SATA drives,...and one DVD Burner. Problem is I cannot get to see all the drives in my computer. Someone told me that the board can only take 2 SATA drives unless RAID is configured. How do I configure RAID on the board ?
I want to run one of the drives on I can connect another EIDE DVD Drive.
Thank you
  • 2,351 Answers
I needed to see your board & can at this site.
This is good for you as well. It shows me & you that your board can handel 4 each DMA/ATA-133 (Ultra) IDE Hard drives/ CD/DVD drives IDE-1Primary & IDE-2 Primary Slave. Each can run 2 IDE drives. Also 4 each Serial ATA SATA's. Two separate SATA controllers with integrated PHYs, each supporting two
drives in master mode. In your manual on pg.32 & 33 will help you to setup a RAID if you wish. Or you can also set the RAID to IDE which will allow you to use all your SATA hard disks as a single drive without setting up a RAID system. The site above supplies all your drivers needed & manual. If you need more help please let me know here.
Please vote......
Posted on Jan 14, 2008
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
Problem Using Windows Install Disc with RAID? Some Tips:
After going through some issues installing Windows onto a RAID partition using this Motherboard, I found some things that were helpful.<br /><br /><span style="font-weight: bold;">#1 Install hangs, or I get an error after Installing RAID Driver.</span> Nowhere in the manual does it tell you this (or at least I didn't see it) but when you install the RAID driver during the windows install, the Motherboard automatically sets SATA connectors 1, 2, 3, and 4 to be RAID. That means if the DVD/CD Rom you are using is plugged in to any of those connections, the minute you install the RAID Driver, the Optical Drive will no longer work. You have to use SATA 5 connector on the motherboard for your optical drive<br /><br /><span style="font-weight: bold;">#2 Multiple Optical Drives with RAID</span>. Because of the issue in #1, there is really only 1 internal SATA Port you can plug an Optical drive into when you have RAID configured. There are some solutions if you want more than 1 Optical Drive alongside your RAID configurations. <br /><br />You can use the ESATA port on the back of the Motherboard with an extra-long SATA cable. If your case has grommets on the back for water-cooling lines, you can run the cable through there, or just in an unused PCI slot on the back.<br /><br />You can use an old-school PATA DVDrom. If you are installing 2 Optical drives, and one is a DVD burner or reader, you could get a PATA DVD Burner or reader instead. This Motherboard does have a good old fashioned ribbon connection, so it's possible. Typically DVDs or CDs don't move enough data to see a difference between PATA and SATA, but when you start getting into any DVD reading/Writing above 8X or so, you will be throttled.<br /><br />Get a PCIe controller card. I think of this as the last resort for this board because of it's possibility with graphics cards. Hooking up anything unnecessary to any of the PCI slots would be defeating the purpose of having 2 full 16X PCIe slots. You might be able to squeeze one in on one of the 1X connections, or maybe the bottom full slot, but it could get cramped if you have 2 or more Video cards.<br /><br /><span style="font-weight: bold;">#3 Windows Installation Issues. DVD Drive Stops Reading during install.</span> I had this issue even after finding out my issue from tip #1. I found that some windows install discs mixed with some manufacturer's DVD drives don't get along well. It would start the installation OK, and get most of the way through it, then it would hang and throw up an error. It seems that during Installation, the SATA DVD drive decides that doesn't like the generic drivers anymore, and just stops working. I fixed this by pulling a PATA DVD drive out of an older PC to use until Windows was fully installed. Once Windows was installed, I pulled that drive back out, and Installed my SATA DVD drive, and Windows installed the drivers with no problems.<br /><br /><span style="font-weight: bold;">#4 RAID Performance. </span>I'm not too sure that I'm getting the best performance from this RAID-0 configuration. I'm running 2 WD Caviar Black 500GB HDDs. My Windows Experience score for the drives is still 5.9. Perhaps the RAID configuration would work better with some faster drives, like Samsung drives, or WD Velociraptors... But I'm unsure.<br />
on Apr 03, 2011 | ASUS M4A79T Deluxe ( M4A79T DLX MB PHENOM...
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mar 25, 2009 | ASUS A7V133 Motherboard
I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother...
Dec 31, 2008 | ASUS M2N-E Motherboard
Nforce4 a939 power led comes on, but nothing else
I am on an nforce asus an32-sli premium, with a 939 in it right now you need a 450 -500V power supply. they are resourse hogs, also are you running anything into the cable or ribbon that the main drive is on, if so try running just the drive and nothing else plugged into the MB as a master 0. Don't forget to connect the sata if you are running sata. let me know if it boots in that config, also clear the cmos and pop the battery prior to booting.
Dec 21, 2008 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
ABit-Th7 raid Drivers
This problem is very simple.... Using RAID in booting in cd/dvd cannot be done in this kind of processing. you have to change the setting of Hard Disk and CD/DVD to IDE in BIOS . To change the setting in the BIOS you need to press the Delete After you power on the computer.. In Main menu in the bios you will find the hard disk or cd/dvd settings to IDE, SATA, and RAID. change both hard disk and cd/dvd to IDE configuration. make sure the first boot in the Boot menu is the cd/dvd, where your windows cd installer is inserted. Save the settings by pressing F10 key in the keyboard.. I have the same problem as of you because i try it to change SATA, RAID but cannot boot to cd and cannot detect the hard disk when installing OS, but in IDE settings its okay.. and it works perfect.. after you installed the windows properly, you can change the Hard Disk or cd/dvd configuration to SATA or RAID. TY
Dec 08, 2008 | Abit KT7A-RAID Motherboard
How can I setup sata drivers using cd or dvd
Hi, I think the problem lies with your bios setting. Set the POST to first boot from the CD/DVD drive. If it is set to first boot from the CD/DVD drive, then the problem comes from the disk. It might not be a bootable disk. If you have any questions, please feel free to contact me. Thanks, Mike H
Nov 01, 2008 | ASUS P4S800D-X Motherboard
Sata DVD burner
This is happening because the DVD SATA is booting like a first drive instead of the IDE Drive.
Be sure that your SATA drive is connected to a right port on your motherboard.
Go to your bios and into the boot options be sure that the IDE drive boot first than the SATA DVD.
Another way is connecting an adaptor SATA to IDE and connect your SATA DVD Drive as second IDE on your motherboard.
This will be fixing your problem.
Have a great day
Pablo :-)
Oct 22, 2008 | Computers & Internet
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Motherboard does not have a SATA configuration on bios setup
use third party raid driver.use floppy drive for installation third party raid driver.
Sep 08, 2007 | Asrock P4VM8 Motherboard
EliteGroup NFORCE4-A939 (NFORCE4A93910) Motherboard Logo
205 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
