Question about Ovens
Gas Smess When our oven is on our house smells of natural gas, the oven attains heat but gas smell over powers the house. Gas Co. could not detect a leak. Please help. Victor
  • nickiell Dec 22, 2008
    Oven and tops burner are off but everyone can still smell gas around the stove. Gas company could not detect leak
  • Anonymous Mar 17, 2014
    High co levels coming from oven when on
The gas might be too high, try turnin it down, or their is a falt with the oven
Posted on Jan 14, 2008
6ya staff
SOURCE:
I just turned on our pilotless oven and noticed the smell of gas. Turned it off naturally. The stove worked fine earlier in the day.
You could have a weak ignitor which can cause a smell of gas, I would have it checked unless you have a way to test for amperage. Test with amp probe should read 3.2 -3.6 amps if less than 3.0 replace ignitor. I hope this helps.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 31, 2014 | Maytag CWG3100A Gas Single Oven
Ignitor working, but oven won't heat, gas in house
if the igniter is not at 100% it won't allow the gas valve to open. Sometimes people say they smell gas. this is another sign of igniter failure.
Feb 01, 2014 | Thermador Ovens
Whirlpool super capacity 465
Call a gas engineer at once. Gas is extremely dangerous.
Jul 19, 2013 | Ovens
Our Viking oven (approx. 8 or 9 years old) seems to be taking longer to preheat and we have noticed a gas smell when the oven is on. Last night, it took at least a half an hour to reach 350.
What type of Gas do you have?-- Natural Gas?-- or Bottled Gas?
The reason I ask, is that If your gas supply is in a tank,-- the tank might be low..)
If you have Natural Gas, and you suspect that you smell gas, You can call your Natural Gas supplier, and have them check for leaks.
So-- If you know you do not have a low gas tank, then you need to call your utility first.
Mack B
Jan 10, 2011 | Ovens
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
Our oven doesn't heat and smells like gas
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 02, 2010 | Maytag Ovens
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Co smell during oven use
What you are smelling is the protective grease against rust or corrosion that came originally with your oven. the odor is normal if you are just purchase the oven.
Dec 18, 2008 | Frigidaire FGB24S5A Gas Single Oven
WHIRLPOOL SUPER CAPACITY 465 MODEL: SF368LEPQ GAS SMELL
I will rarely say "call a professional" here because this is a do it yourself site right?
However, in this case, you obviously have a gas leak and/or malfunctioning gas valve.
Unless you have experience and training in detecting gas leaks I highly recommend shutting the gas off to the unit, ventilating the area, and calling a pro.
Gas can be very dangerous if handled improperly and a mere spark can "make house go kaboom".
If you are smelling it strong enough that you have to open windows, it is a potentially dangerous situation.
Dec 06, 2008 | Ovens
Gas oven won't heat
You most likely have a defective oven bake ignitor.  Call an experienced tecnician.
Oct 09, 2007 | Ovens
Ovens Logo
166 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
