Question about Sony Cyber-shot DSC-W55 Digital Camera
Camera will not stay on
Turn camera on i have a flashing battery above the words saying for use with compatible battery only then shuts down,can you please help me
kind regards bob
  • 2 more comments
  • sefeba Feb 05, 2008
    I have the same problem. And that solution is no useful because you do not have enough time to go to the menu, it turns off very quick. Please help.
  • Anonymous Jul 17, 2008
    same problem same camera!
  • mariafsampai Aug 27, 2008
    I bought a SONY DSC-S750 3 months ago. Since last week, when i turn the
    camera on, appears the message "for use with compatible battery only".
    The battery came with the camera. The camera was bought in a big store
    in Philadelphia. I WILL NEVER BUY A SONY CAMERA AGAIN. I already tried
    to reset, tried to remove the battery and the problem persists.
  • Anonymous Nov 12, 2008
    same problem and power off very fast
  • 23 Answers
Please check if the battery supplied is an NPBG1 battery.
or try this...
1.turn the unit on
2.press the menu button
3. select setup
4. inside setup and search for setup 1 (option with a toolbox icon with a number at the bottom.)
5. inside setup1, pls select initialize and reply with OK to evety prompt(using the center button)
6.if succesfull(you'll get clock settings)
7.set the date and time then try the camera again.
if this does not work.... call sony cust service 1800-222-7669
Posted on Jan 30, 2008
Camera will not stay on, have a new battery and according to directions
i want to know if there is some flash to use in video way with my chamber
Dec 10, 2013 | Kodak EasyShare M863 Digital Camera
Turns on then shuts off
1) Remove battery
2) Use AC Source : OK
Yes: Can be battery - Easy, Can be board - Not that easy
NO: Getting that warning can be helpful.
Little tip to read quick messages, read it word by word after resetting it time to time.
Note: The above tip is not recommended and only if you have the courage to face the consequences of resetting a malfunction system time to time.
Dec 08, 2013 | HP Black 14" Pavilion Special Beats...
My camera says " use with a compatible battery"
Sometimes its because the battery terminal is somewhat dirty. I would try cleaning
the inside of the battery compartment (where the metal contacts are) with a
q-tip dipped in alcohol. Let it dry (blow on it to assist the drying process). Then give it
a try. If that doesn't work then you will probably need a replacement board because
the sensor is bad. Have a qualified Tech take a look at the camera
Feb 12, 2011 | Sony Cybershot DSCW350 Digital Camera
580ex off camera shuts down after a minute or so of standby
No and no, the flash is by default programed to shut off after 1 minute .If you were using the flash on-camera, the flash would automatically power itself on when camera activity is detected but when the flash is detached, it doesn't wake back up.
To change this you have to turn off the auto shut off in the flash menu:
1. Power the flash on
2. Hold down the back light /C.Fn button until "Fn 00 0" appears on the screen
3. Rotate the selector wheel until you see "Fn 01 0"
4. Press your selector button down so that the 0 begins flashing
5. Rotate your selector wheel to change the 0 to a 1
6. Rotate the selector to the "Fn 14 0" position and set it to 1
7. Press your selector button to save this parameter
8. Press your Mode button to return to the main screen
Now your flash stays on as long as the flash switch is turned on ON, and as long as you have juice in the batteries.
Do not forget to turn off the flash after you are done.You can reverse it anytime, but you have to read the manual for that..
Same setup can be found in the manual
May 07, 2010 | Canon SPEEDLITE 580EX TTL Flash
My camera wont stay on even with new batteries
I Have The Same Exact Camera As You And Have lost of Experience With Digital Cameras I'm Guessing you just need digital camera compatible batteries (Rechargeable) Oh and keep in mind taking a picture requires a lot of energy use
Dec 30, 2008 | Polaroid i735 Digital Camera
Even New Batteries Wont Work. Camera Shuts Down Immediately
Clean front and back + - terminals in camera careful with fine emery paper. Also, MAKE sure batteries are not loose if they are they will not make the connection. Fine jeweler screwdriver will pick them out enough.VERY CAREFUL.I truly think this is it.regards Billy
Oct 11, 2017 | Canon PowerShot S100 Digital Camera
Camera on for 5 seconds red flashing light then turns off
that definitely sounds like a battery problem.
when you charged the battery, did the light stay red, and then turn green when it was finished?
if it flashed red, try this:
MATERIALS: 9 volt battery, 2 pieces of wire the same length, casio battery
DIRECTIONS: connect the + sides of each battery with a wire, and the - sides of each battery with another wire. [I just held them there, but maybe you can tape them if you're having trouble.] Hold it for 30 seconds. Then try charging it. If it doesn't work keep trying it until it does. TRUST ME! It took me 5 times to do it effectively.
If your battery has gone too long without charging, sometimes it won't charge correctly any more. So do this.. IDK why it works, but it did for me!
Nov 19, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
When i turn on my camera it flashes"for use with compatible battery only" then turns off
Hello, try to replace the battery (purchase the new NP BG1) If you need more info please advice.
Jun 07, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
174 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
