Question about Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88
Only prints correctly in draft mode. When I try to print anything else, I get bands of colors across the page, and midde of photo is all muddy. It was working fine a efw days ago, and nothing has changed!
My printer will not stop printing despite having been disconnected and turned off in an attempt to stop this from happening
Posted on Jan 21, 2008
Epson Stylus C88 - New Epson Factory ink cartridges. Nothing prints, although printer goes through the motions of printing. What could be wrong? Ink levels are fine.
You should run a nozzle check to verify if the heads are printing all the inks correctly. If the pattern is incomplete you need to run head cleanings.
Apr 30, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Apr 02, 2009 | Epson Stylus C88 InkJet Photo Printer
EPSON Stylus C88 Series not printing blue ink
From the lack of interest by koolcorgipro in this problem, I think we may say it has been solved by the poster.
Feb 23, 2009 | Epson Stylus C88 InkJet Photo Printer
Inaccurate color printed
Check the color profile settings for your printer. Also, make sure your not using any kind of draft mode. Are you using refilled cartridges or off-brand ink?
Dec 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson C88 printer only prints blank pages
See my post about about underhead cleaning. If that makes no difference you will need the countermeasure for the split cap tube. The document about loss of ink on CX series machines is also applicable to C88
Jul 18, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson R265 Printer
2. TRASH and REINSTALL the drivers
3. Try a different application and file
4using a PHOTO PRINTER (Stylus PHOTO) try to set the QUALITY OPTION to BEST PHOTO or PHOTO RPM
5. Go to PRINTING PREFERENCES and hit ADVANCE
6. Choose the right PAPER TYPE, SIZE and SOURCE then disable HIGH SPEED
7. Once all those are set choose PHOTO RPM under the COLOR MANAGEMENT box and try printing
8. This will print a lot slower but will be using alot of ink and eliminate the lines
Apr 04, 2008 | Epson Stylus R265 InkJet Photo Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 Printing Problem
print the test page and check its working or not and getting clearly or not set the printing level is normal then it prints slow , i think your image comes best try it or again post it
Mar 15, 2008 | Office Equipment & Supplies
C88 printing in grey instead of the color
In the Print dialog, go to 'Properties.' Screw around in there for a bit.
Oct 17, 2007 | Epson Stylus C88 InkJet Photo Printer
C88 printing purple instead of gray
check and make sure the cartridges arent faulty and that the ink color matches
Oct 13, 2007 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 InkJet Photo Printer Logo
87 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
