Question about Sony KP-53HS10 TV
Should I buy this set used or are there many problems with it? TX J
Please let me know. It is going for $500. and they say they bought it 1 1\2 years ago.
  • buyerJ Jan 14, 2008
    Thanks you just saved me a lot of money, frustration & TIME!
    You are guys are GREAT!
Do not under any circumstances buy this TV unless you are a service technician. The people who are trying to sell it to you probably already had to have it fixed once before and "forgot" to tell you. This TV is the definition of Lemon. Tell them you know the thing is gonna break and you'll give them $100 to take it off their hands. Otherwise be prepared to replace the power supply in a couple months and spend tons of money or man hours trying to get this thing to work.
Posted on Jan 14, 2008
Is there a reset on tx-nr801. And how
To reset the surround mode and other settings to the
factory default settings, hold down the VIDEO 1 button with the TX-NR801/TX-NR801E turned on and
then press the STANDBY/ON button. "CLEAR"
appears in the front display and the TX-NR801/
TX-NR801E enters the standby state.
Mar 08, 2018 | Cars & Trucks
PoE Cable for Polycom IP 500
Check if the switch uses active or passive PoE and the volts it pushes out
Active(PINS)1 2 3 4 5 6 7 8RX/DC+ RX/DC+ TX/DC- n/a n/a TX/DC-
Passive(PINS)1 2 3 4 5 6 7 8RX RX TX DC+ DC+ TX DC- DC-
Cat 5 cable9V < 30m cable length12V < 60m cable length
Max Ethernet cable length is 100m
Jan 14, 2012 | Polycom Poe Cable for Cisco For Use with...
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
MY OLYMPUS SP 500UZ constantly kills batteries...any ideas? I can't go even an hour without replacing batteries most days.
The best thing I EVER bought for my Olympus was the Re-chargeable Lithium Ion battery. The worst thing I did was buy an off brand. That was a waste. I ended up getting the more expensive brand Olympus recommended and all was GREAT again!! 1,000's of pictures later and they still work great.
Good Luck
Dec 25, 2009 | Olympus SP-500 UZ Digital Camera
No power, TV set just died after 1 year, brought brand new.
my samsung tv has been by lightening ( model tx-t2782) what are the steps to testing voltages in different areas.
Sep 07, 2009 | Samsung SlimFit TX-T2782 HDTV
SR573... Does it support NTSC/PAL?.
There's no mention of either NTSC or PAL in any spec sheet.
This link leads to Onkyo and the rear view of the amp lacks the voltage selector.
The manual for the similar model SR575 says the North American model does not have the voltage selector. Too bad. Under the general specs for the variants of this family of receivers they list the following power specs. I have no idea where you have to go to buy one from the "Others" group.
Power Supply North American: AC 120 V, 60 Hz
European: AC 230 V, 50 Hz
Others: AC 120/220-240 V, 50/60 Hz
AC 220 V, 50/60 Hz
Some aliases for the SR575=
You could do what I did over 30 years ago. Join the Army, go overseas and buy one in the PX. Every HiFi product we bought in the PX in the 70's had the dual voltage feature.
Apr 07, 2009 | Onkyo TX-SR573 Receiver
Onkyo tx 906 amp
1) I bought the same Onkyo model from goodwill a couple years ago and it had the same problem. The solution is simple: Get yourself some Deoxit D5. This is a spray that will clean out all the oxidation in the volume pot. To do this you'll need to remove the cover of the receiver. Deoxit can be bought at guitar shops, or if you know a musician they might be willing to do it for you.
2) User manual is available for download, for free. Google "Onkyo tx-906 receiver manual".
Mar 17, 2009 | Onkyo TX-DS575 Receiver
Onkyo TX-DS595 with no display?
Ran my 595 blind for 2 years and finally spent the time to diagnose it this year. Turns out that one of the resistors that is on the power supply went bad. Similar problems have happened with later models so i thought the same may be true for the DS595.
My Receiver has always run fine.. just no display anymore.
Here's the fix. Replace R9501. its on the larger board that is part of the Power Supply. You will have to take the 4 large screws out of the base of the big heavy power supply block to find the resistor. I believe the old resistors is a 1/4 Watt. I replaced it with a 1 Watt so that it can handle the heat of being turned on and off better.
The resistor you will need to buy is 2.0 Ohm. I wouldn't go anything less than a 1/2 Watt and preferably 1 Watt.
My receiver works line new now!
Nov 15, 2007 | Onkyo TX-DS595 Receiver
Having problems connecting dvd vcr combo to tv
Hey Pat. Red Yellow White Plugs into back of MVD4544. Red Yellow and white plugs into back of TV. If you have an older TV that has only coax cable outlet, go to Radio Shack or Best Buy and get an RF Modulator. You may need to get another set of Red Yellow White Plugs if you have a cable box. The front connections are Video 2, if placed on the back they are Video 1. When you first turn the DVD/VCR player on, be sure to select the appropriate setting. If you figure out how to timer record on this please let me know. No where in the 52 page book is there any info and their website is a joke. Good Luck.
Sep 14, 2007 | Televison & Video
Onkyo Forgets it's input settings during power outages
yes there is ,,, it is located on the same board that has 3 fuses on it, you will have to unplug the unit before disassembly, and remove the top cove and bottow covers,,,, you will have to de-solder a small battery pack surrounded by either blue or yellow heat shrink,,, please not the polarity before removal, as putting it in wrong will cause a non- memory retaining situation to continue...I hope this helps
Jul 07, 2007 | Onkyo TX-DS787 Receiver
Sony KP-53HS10 TV Logo
32 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
