Check your wire connections on the back of the tv to make sure nothing had caused them to get unplugged OR been chewed through. If it doesn't fix the problem then try replacing your connections.
Originally Answered: What does it mean when your TV has a black screen but is still producing sound? Unplug the power to the external device for 30 seconds. Disconnect the HDMI cable from the TV and move it to an alternate port. Plug the device back in, and power the device back on.
https://www.quora.com/What-should-I-do-if-my-TV-screen-is-black-but-there-is-sound
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
If you are seeing light then the back light is working. Can you get a menu?Do any of the other video inputs work? If no video but has backlight and no men or any on screen display replace main board.
Make sure your tv is on the right input first of all. The newer flat panel lcds combine the componenent video (red , blue, green) with the composite video and audio (yellow, red, white). If your tv is on the component input then you hear audio from the composite input since the audio inputs (red, white) are shared. Look for a source or tv input button on your remote or the tv itself and try pressing this button unti you see a picture with sound.
Try Shining a bright light at the screen. can you see any images on the screen? If you can, then the backlight on the tv has gone, and can be replaced.
If you cant then it may be a fault with the inverror (power) board on the TV
