Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Gas powered ryobi trimmer will not start
How do I start it. I've ran it doing the summer but now it will not start even after I changed the spark plug.
  • 4 more comments
  • Anonymous Jan 24, 2008
    Ryobi 18 In. 30CC Straight Shaft Trimmer will not start
  • jimmeister Jun 04, 2008
    My ryobi gas trimmer has been used only one season. Now, I am unable to get it to start--at all. Any suggestions?
  • scooter59 Jun 16, 2008
    I have the same problem....is this something indicative of Ryobi? I have cleaned spark plug, dumped gas, and pulled and pulled and pulled! Is it time to throw it in the trash?
  • bodoz Sep 27, 2008
    died and changed spark plug but acts like no psark is getting to engine
  • vernonnewman Mar 26, 2009
    ihave the same problem ! ran fine and then would not start. changed the spark plug and still nothing. what else could it be ?
  • Anonymous Apr 03, 2009
    I have the same issue, just picked mine up from the mower shop in pieces I may add ( a long story) it needs an ignition coil kit.
    hope it helps
    Problem Solver:
  • 5 Answers
Hi
I found that the plug that came with my unit had an intermittent fault (sparked sometimes, then not all) definately the plug in my case. And yet at first, seemed to start OK, progressively got worse.
OK so youve changed the plug! Now check for spark....Can you see the spark if you pull the cord a few times
(you have to unscrew the plug from the head but leave it connected to lead & rest the plug against the metal cylinder surface using a pair of pliers to steady it and so you dont get a small shock)
If youre getting visable spark when you pull the cord, suspect fuel feed blockage from carb, Test by: Prime the bulb & turn to full choke, pul the start cord, Is there petrol vapour/odour present within the cylinder with the spark plug removed.
Check also gauze air filter behind the roto choke knob is clear, on/off switch (could be damp wd40) Test compression put your finger over the open plug port, plug starter cord, should be a little pressure build up
Hope this helps
please rate my comments - thanks
Aky1967
Posted on Feb 05, 2009
    New Friend:
Thank you will try
Posted on Jun 06, 2013
Can not get my Ryobi gas trimmer to start. It is fairly new and have never had a problem. It is getting gas and I've changed the spark plug but still can't get it to start.
There are 2 stroke and 4 stroke Ryobi's. The most common non-spark problem is the coil. (at least for me) Is it getting spark???
Sep 12, 2011 | Ryobi Garden
My Gas Powered Ryobi String Trimmer (RY26500B) won't start. What should I try??
Here are the basics. You need: spark, fuel, air, compression, and timing to make it run. Clean the spark plug. Inspect the fuel lines. Are the hard/brittle? Do they connect to the filter in the gas tank? Clean the air filter. When the spark plug is out, put your finger over the opening and gently pull the rope. Do you have compression?
Most common repairs needed are usually fuel lines and carburetor work.
Aug 20, 2010 | Ryobi Garden
Ryobi 700r trimmer does not start. Changed spark
hve you checked the HT lead and the on/off switch i had the same model as this and i changed everthing but in the end t chucked the thing away and got a sthil modle
Jun 21, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Troy weekwacker, and after sitting this winter, it WILL not stay running. The only way to even get it to start is to load the thing with starting fluid, and then it only runs til it eats up all...
Have you changed the spark plug on this unit? If all else has failed, this is more then likely the problem. Please let me no if it takes care of the problem.
Sincerely, Shastalaker7
Apr 14, 2010 | Troy Bilt Tb70ss Gas Trimmer
Can't get my Ryobi CS30 trimmer started, bought a new spark plug, still won't start. It worked fine last summer, took it out for the first time today, won't start, has plenty of fuel
Is the fuel old or has it been drained and refilled?? Sometimes old fuel will do this. Also make sure the air filter is clean and free of oil/dirt as this will also hinder the starting.
The primer button also is something to check. Push it 7 times, full choke, pull for 5 times, turn to half choke, and the unit should start.
Let me know,
Chip
Apr 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
My ryobi cs30 wont start
what do you do when there is no spark??????????????????
how do you fix???????????
Mar 26, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 780 Trimmer No Spark - won't start
Hi
Check the spark at the plug,compression and carburation.Clean the air and the fuel filters.Check the muffler.
best regards savumihai71
Sep 17, 2008 | Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
557 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
