My car got stuck in park several times, i'm the brake lights would come on but i couldnt push the button to make my car move out of park...there's a tab on the right side at the top of the gear shifter console pop it out, stick a skrew driver down in and that should release it if that's your problem...it's a little bit of a rig, but it works, havent been stuck in park since
it'sthe solenoid at the top of brake to be able to shift when thios goes out there is a little plug on the console on right side of shifter pull this out and take a screw driver or even a straw and push down you will be able to fill the lever when you push down this will let you shift normally til you replace solenoid.
I have this same problem. It has caused me to be late for work and almost lose my job!! My fix is just to leave in Neutral w/ parking break on when the car is off. It seems to be weather related because when the temp drops below 40 degrees, I experience this problem. To get it in to Neutral, you have to turn the car off with the shifter in park and the button pushed down. It takes some practice to get the hang of it, but it works everytime for me.
Is shifter loose if yes broken shifter cable if not mouving try to remouve center cansowl .and ther is litle solonoid tap on it and try to shift
If the shifter moves and still doesn't shift try getting the neutral safety switch checked
