Home | kawasaki | 19.2V 4 Piece Cordless Tool Kit | Kawasaki 19.2V Battery
kawasaki 19.2V 4 Piece Cordless Tool Kit
Problem for kawasaki 19.2V 4 Piece Cordless Tool Kit
By slvrbullit on Jan 13, 2008
Since the day I brought the 19.2V drill home, I have had a problem with the batteries holding a charge.
Same Problem
May 17, 2009
-   My charger light -will- come on, but dims out after about 10 seconds! I don't think it's charging! :-)
-   Guest
Dec 11, 2008
-   bought the drill from OSH - battery will not hold a charge and charger will not turn on (light) when the battery is plugged in.-   Guest
Apr 21, 2008
-   i've had the same problem...the batteries won't hold a charge & often the charger doesn't turn 'on' properly.-   Guest
Best Solution
posted on Apr 23, 2008
Helpful)
Ask Carl
Rank: Master
Rating: 84%, 19 votes
Your problem could be the battery or possiblt the charger but call 1-800-423-3598, give them your model number so they can provide you with either a replacement or a refund.
Was this helpful?
Yes
No
Solution #2
posted on Sep 28, 2009
Somewhat Helpful)
eeclipse7769
Rank: Wiz
Rating: 83%, 40 votes
Danger!!! There is a RECALL NOTICE in effect for batteries and chargers for Kawasaki 19.2v systems. Go to the website and check your model number and they will ship you a free charger, if your model number is affected, RECALL NOTICE
Was this helpful?
Yes
No
Solution #3
posted on Oct 21, 2009
Not Rated)
harlan301
Rank: Guru  Tools - Building & Power  Expert
Rating: 90%, 47 votes
As before do not call Kawasaki. call All Trade 800-423-3598 as the tech before let you know. good luck. PS thy are coming out with a higher Amp switch.
Was this helpful?
Yes
No
Popular Solutions for kawasaki 19.2V 4 Piece
Questions and Unsolved Problems for kawasaki 19.2V 4 Piece
Do you recommend kawasaki 19.2V 4 Piece Cordless Tool Kit?
Answer
Answer
I have a walter drywall screw gun model 6343. the bit holder releases the bit and it is very... (More)
Answer
lost power pack for recharging wagner 16.8v classic pro
Answer
I have had two cordless drill variable speed triggers burn up and render the tool useless (original... (More)
Answer
how do you connect the wire connections for the power switch?
Answer
screwed 75 2 1/2 inch deck screws worked great, came back the next morning and zip doesn't work.... ... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For kawasaki 19.2V 4 Piece...:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
