Question about Beko 324250WN 28" TV
Televison probs We have accidentaly put a magnet on the tv and the colours went green, red and blue. The problem lasted a few days and then resolved itself, but now it has gone back to being green, red and blue. Can we demagnatize it our self without spending a fortune?????
    Novelist:
  • 139 Answers
You can demagnetize it yourself if you have a friend in the TV repair business who will loan you a demagnetizer. ...or you may be able to buy an inexpensive one on-line. A TV demagnetizer is basically a coil of wire approximately 12-15 inches in diameter...but don't try to make one yourself...it must be properly insulated for safety. To use it, you plug it in, turn it on and hold it in front of your TV screen...then begin to move it around the screen using a slow steady motion...for at least a minute...and then slowly pull it away. Do not shut off the demagnetizer until it is at least 5 or 6 feet away from the screen or you'll make the color problem even worse.
Posted on Jan 13, 2008
  • 102 Answers
Most tv's degauss themselves when turned on so turning off and on a few times might help. Leave about 15 minutes between on off cycles and keep on trying untill you see improvement. You could also get hold of an old tape eraser, plug that into the mains and starting from a foot or so away try to brush the badly coloured parts away without coming to close to the screen.
  • I forgot the line where networkmagic said '. Do not shut off the demagnetizer' Indeed do not switch off before you are 5 or 6 feet away from the screen :)
Picture is pink in places and dark scenes the picture is mostly green
Oh dear.
It sounds like you have magnetised the screen by placing something magnetic too close.
Your only hope is to unplug the TV, and remove ANYTHING magnetic away from it, such as speakers etc. Give it a few hours then retry.
If this has been going on some time, it will already be too late.
The other possibility is the tube could be going!
Jan 10, 2018 | Panasonic TX-36PF10 TV
My Daewoo TV just went to all purple and green
Do you have speakers near the screen like stereo speakers ? if so move them away see if that helps , you will need to shut off tv for a while once speakers are moved , if that dosent fix it , u may need to adjust the 3 nobs which are behind the tv, you will need to remove the back of the tv cover , please remember safety , the should be 3 knobs which u can turn , one is for blue ,green , and red , adjust these until the screen is normal again, magnet's are the biggest cause of this problem , as a last resort for home fix it , u can sometimes use a magnet on the front of the screen to shift the colours around , i have used this method a few times and its worked ! , but its not reccomended and i suggest u do this after all else fails ,
Dec 07, 2007 | Televison & Video
Hitachi L32HO1UA HD TV blurred images very dark unwatchable scree
Hi Ellie!
Maybe in the manual you can find any information how to resolve this problem.
On this page of the manual there are shown most common receprion problems: http://manualsbrain.com/ru/manuals/979781/?page=72
Apr 26, 2017 | Hitachi 61SWX10B 61" Rear Projection...
I have a bush colour tv and there is a blue,green,red colour wash right across the picture so people''s faces look half blue,green red....sort of as if there is a rainbow across the screen.. i do not have...
It sounds like your TV may need degausing.
Is your TV situated near to any loudspeakers or other devices with large magnets inside them? Or has anyone been near your TV screen with a magnet???
You need to try to get the screen demagnetised (degaussed). Many TV engineers have a degausing coil that could do this. It only takes around 20 seconds at most.
Some TV's like Mitsubishi have a DG button on the remote, that does this function without the need to call out an engineer! It only needs one press of the button every few years!
Nov 17, 2009 | Televison & Video
Colour problems on TV
try to disgusting it and next time don't near it the magnet or speaker
Sep 25, 2009 | Televison & Video
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
COLOUR PROBLEMS
Greetings!
This sounds like a degaussing (named after 19th century scientist Carl Friedrich Gauss) problem. This usually occurs one of several ways:
1. The TV fell down and went "boom".
2. Junior held a magnet up to the screen when you weren't looking.
3. There is a large, unshielded speaker near the set.
4. The TV was rotated in relation to the North/South magnetic poles of the Earth while it was running (yes, really).
All televisions have a degaussing coil built into them which is activated momentarily every time you turn on your TV. This typically will cure all minor anomolies over the course of a few days. However for a severe one like you have, it will probably require a trip to your friendly repair shop. I, personally, do not charge anyone to perform this service because it takes, literally, 5-10 seconds to degauss a TV. I simply ask them to remember me next time they go to buy a new TV or need service work. I can't say that your technician will do the same.
In the case of the first instance of the TV falling down and going "boom". If it fell with enough force to warp the shadow mask built into the picture tube, then all of the above information means nothing. The set will require a picture tube replacement to cure the problem.
Hope this helps,
Rob
Jan 14, 2009 | Televison & Video
Need help repairing Mitsubishi VS 4541 rear projection TV
Visit the site linked here for more details. Repair of many popular brand devices are given. http://electronicshelponline.blogspot.com/
Mar 23, 2017 | Televison & Video
TV shadows
Check the proximity of magnetic fields. Large Speakers near the TV for example will cause colour distortion.
Dec 24, 2007 | Televison & Video
Beko 324250WN 28" TV Logo
427 people viewed this question
Top Beko Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
