Question about Brother GX-6750 Typewriter
Paper not feeding
Paper can easily be slid around the rubber platen. Is there a paper release that I do not know about. Of course in this condition the typewriter can not catch or feed the paper for even the demo test.
  • keynoteman Jan 13, 2008
    Thanking some kind soul in advance for taking a moment to help.
  • Brother Master
  • 3,594 Answers
Paper release is ont. hand side of the machine.
DickyO
Posted on Jan 17, 2008
Brother M-100 Won't Grip Paper
Best way is to remove the top cover, with out taking the Platen(large rubber roller) that the paper goes around out look to the rear there is a spring that breaks that puts pressure on a pan with feed rollers in it , replace spring or at least put a new hook in it or if you are lucky and it is not broke I could just be unhooked. Also clean all those rollers that are rubber with something nail polish remover. Do not touch plastic with this cleaner, it may melt plastic.
Apr 04, 2014 | Brother Office Equipment & Supplies
My MP 830 printer will no longer feed copies from the automatic document feeder. The machine makes noise like gears slipping and the paper goes one fourth of the way and then stops before it can go down. ...
Check the feed roller on that paper tray. if the roller is made of rubber clean it with the eraser on a pencil making sure to clear away any extra dust. the Eraser will re-surface the roller to grip better.
Also check inside not just for blockages but sensors that may be stuck, such sensors may look like black armatures that move easily and light sensors that easily clog with dust.
Remove the print cartridge and dust out the entire paper path.
May 02, 2008 | Office Equipment & Supplies
Gx 6750 carriage daisy brogham
If you can remove the platen, roller, you may find a label stuck on the deflector. Remove the label from the deflector. Make sure the deflector is installed properly.
Nov 05, 2013 | Brother ML-100 Typewriter
We have a brothers GX-6750 that wont feed paper, wheel just spins.
If the Platen is moving the paper release lever is in the wrong position, if the platen isn't moving the paper feed motor will have to be replaced.
DickyO
Dec 01, 2010 | Brother GX-6750 Typewriter
Pls how do i insert paper for typing?
on your left hand with top of platen release that leaver and insert the paper from beyound near the platen then the same leaver release into old position and with forward the platen knob the paper will be feed up to your desiered position
Nov 25, 2010 | Olympia Office Equipment & Supplies
I'm getting an error code of W8102. Can anybody out there tell me what that means??
W8101/8102 - Print media position warning
The paper over the platen lies too near or too far from the carriage home position
when fed into the printer.
Cause>
The paper on the platen was too close to or too far from the carriage home position
side when paper was fed.
<Probable faulty component>
The way in which paper is set, print paper, cassette/cut-sheet feed unit, carriage
unit, encoder sensor unit, linear scale, carriage controller, head controller, system
controller.
<Action>
1. Paper setting check:
Reset the paper if the setting is not correct.
2. Paper check:
Replace the paper when any stains or pre-prints are found.
Straighten or replace the roll media when the roll of paper is ruffled.
3. Cassette unit/cut-sheet feed unit:
Replace the faulty paper feed component when the paper feeding is performed
correctly in all parts except where the error occurred.
4. Check the linear scale:
Visually check the linear scale for abnormal conditions, such as stains or damage.
5. Replace the carriage unit.
6. Replace the head controller.
7. Replace the system controller.
May 18, 2010 | Canon BJ-W9000 Copier
The IBM Wheelwriter 1000 won't grab the paper I put into it!
There are a few possibilities.
first be sure the paper release lever on the top left side is to the rear, if it is push firmly down on the platen (blacl rubber roller) they do work themselves out. If the platen isn't turning you may have a board problem.
DickyO
Nov 12, 2008 | IBM Office Equipment & Supplies
Smith Corona 235 DLE doesn't advance
Does the platen move or does the paper not advance? Check the paper release lever to make sure the feed wheels are snapped in place. If the platen does not move something in the paper feed motor area.
Jul 28, 2008 | Smith Corona Wordsmith 200 Typewriter
Smith Corona 240 DLE
pull the paper release lever and look under the platen as well as you can, to see if there are any forien objects. check if the feed rollers are all in place. the slots in the paper pan under the platen should have rollers in them
Jun 26, 2008 | Smith Corona Wordsmith 200 Typewriter
PAPER WON'T FEED THROUGH
The tension spring has probably come loose I can e-mail you a copy of the platen removal and replacement page from the repair manual jcagle12@msn.com
Nov 07, 2007 | Smith Corona Wordsmith 200 Typewriter
Brother GX-6750 Typewriter Logo
216 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
