SanDisk 4GB Memory Stick PRO Duo Memory Card Logo
Posted on Nov 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sandisk memory stick duo. The pictures and videos can be viewed while in the sony webbie. When I plug it up to transfer the pictures/videos to the computer I get an error message. Is there anything I can do to get them off of the memory stick?
Anonymous
Level 3:
  • SanDisk Master 32,281 Answers
  • Posted on Nov 25, 2009
Anonymous
SanDisk Master
Level 3:
Answers
32281
Questions
Helped
7908046
Points
102259
Connect the memory card/stick to a USB memory card reader and then plug it into the USB port in the computer. The computer will see this as an external memory card.
I recorded a video on my Sony Webbie MHS-CM1, I was able to view it on the camera. I inserted the memory stick pro duo on my TV with an adaptor (it has an SD memory card slot) and it said that the memory...
Hi , You need to get or buy a card reader. This is something you can use on a computer to read files stored on the card. Mpeg,jpeg,Mp3,and mp4 muvie files. Go to your nearest Audio and Video store and they maybe able to help you. Good luck.
Not able to view pictures from sandisk memory stick pro duo on my laptop when connected using card reader or by using the USB cable of the digi cam directly.
Don't know about cam (was there a software disk to install?).
As far as the reader goes you reader must be compatible with both devices.
Hope this helps
I am unable to view and transfer my pictures from my sony digicam to my pc.please advise what do i have to do, how do i save those pix on that memory card?
by default the pics in sony digicam is stored in memory card.. so you can connect the memory card with pc with the help of card reader.. then you can easily view and transfer pics from digicam to pc
How do you transfer video on the hard drive to the memory stick?
Unable to transfer a video recording made on the hard disk drive to the Memory Stick Duo™ media Solution
sp.gif sp.gif Do the following before attempting to copy movies to the Memory Stick Duo media:
  1. Ensure an Image Database File has been created on the inserted Memory Stick Duo media.
  2. Ensure there is enough space available on the Memory Stick Duo media.
NOTE: For model-specific information about how to transfer a video recording, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
"Format error" with sony MHS-CM1 webbie, 16GB produo
There is a firmware update available for your Camcorder at this link http://esupport.sony.com/US/perl/swu-list.pl?mdl=MHSCM1&SelectOS=7 Download and follow the site instructions for installing it. The high capacity memory stick PRO is probably beyond the current camera's capacity to recognize and the firmware update should fix it.
2answers
Does Sony cybershotdsc w 220 digital camera supports 4 GB SDHC memory card
the dsc w200 can easily handle 4 gb memory stick duo and duo pro but not SD cards ..
Transferring photo from computer to memory stick
Many cameras will not let you write to the card. Try using a card reader, which will make the memory card appear to the computer as a separate hard drive.
Psp illiterate
Yes there is a way. What you will need is a PC, Some form of Memory stick Duo card Reader, And a PSP Compatible Memory stick Duo/Pro Duo.
If you havent already used the memory stick inside the PSP it will not have the correct Formatted file System for use in the PSP. but you can create the file system using your computer.
heres how to do it ! :
1) plug your Memory stick Duo/Pro Duo into the card reader on your computer.
2) open my computer, locate the Memory stick usually found under the "devices with removable storage" area.
3) once inside the memory stick, create 2 seperate folders. One called "PSP" and the other one called "MP_ROOT".
4) Navigate into the "PSP" Folder and create 3 Folders, "MUSIC", "PICTURE" & "VIDEO"
5) Copy & Paste the Necessary files into each Subsequent Sub-Folder within the "PSP" Folder.
Note : The PSP Can only handle Certain File types for Pictures, Music, And Video. i would suggest Navigating to http://psp.about.com/od/hardwarefirmware/p/compformat.htm before you transfer your files to ensure that you are adding files which are Viewable/Readable by The PSP's software.
Hope this helps !?
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
