Beko 42 plasma tv
Hi, Recently i have noticed that i have alot of what i would call " fizzing " of the pixels on my screen, especially when the screen has something dark coloured on it. The pixels seem to flash and appear to be moving constantly? If i turn off the tv for 30 mins or so, then turn back on, everything appears normal, then gradually the pixels start to " fizz ". Have you any idea what could cause such a problem? I dont want to go to the hassle or cost of having an engineer come in and then teel me it's interference from something else in the house, is this likely? Thanks, Walter Cairns.
  • tyson8000 Jan 14, 2008
    i cannot see any info on tv that relates to either va or vs voltages. Is there anything i can do to solve the problem or am i likely to need to get the repair guy out?
    Thanks, how would i be able to apply the new software? if there was an upgrade available.
    Genius:
  • 1,153 Answers
Sometimes in these cases it could be as simple as Software up grade, which you would have to get in touch with Manufacturers
Posted on Jan 14, 2008
  • Lashawn Robinson Jan 14, 2008
    Call manufacturer and ask if they have an upgrade MMC card for your model and make!
    Genius:
  • 1,030 Answers
I have encounterd a simular problem with sets like this. THere are voltages called va and vs voltages that have to be certain levels. when the set warms up thes voltage change and causes the symptoms you decscribe. ussally there is a sticker in these plasma that list what these voltages should be it is relative to the type of panel used in the set.. example the one im looking at right now is va=72 volts vs=175 volts.. there a mini pot adjustment that can be used to adjust these and sometime it might help. WARNING .any adjustment made to set can potentially cause more problems and should not be atempted by non technicians.
  • Willie Howell Jan 15, 2008
    These voltages would best be adjusted by a technician
    The levels are on a sticker inside set
6ya staff
SOURCE:
Dead Pixel Issue?
It must be really hard to get all the pixels in a large screen to be working. I've seen many with a very small number of pixels dead or stuck at one color
May 09, 2014 | Westinghouse Televison & Video
Blurry pixel display of AOC monitors.
Hi, In my experience, it looks that the screen pixels are damaged in some areas. It could be due to mishandling, may be fallen or it could be a manufacturing defect. If the device is new, ask for the replacement as it may enlarge due to heat. Rest is your luck :)
Sep 28, 2017 | AOC Monitor
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
Discolored Sides
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.Ths if your tv is a dlp if its a Lcd it will be an issue with your light engine: Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Mar 29, 2010 | Televison & Video
Black dot on Lumix Fz18 screen
It is either a faulty pixel in the CCD or a piece of grit in the lens. has it moved at all.
If it moves it's a piece of grit.
Will require servicing, they can either remove the grit or remap the pixels in the CCD.
Cheers.
Sep 21, 2009 | Panasonic Lumix DMC-FZ18 Digital Camera
Pixels aren't refreshing correctly in upper right hand side of screen
You might have a Service Co. come out and look at it. It sounds like the Z module is not doing it's job of erasing all prior images after a scene change. Some models there are adjustments for that internally. ( only for a tech ) Start a paper trail now.
Apr 28, 2009 | Televison & Video
Bright blue pixels on left side of plasma screen
try to adjust Vs & Vsc within 5% of their spec on the power supply board when you notice the problem.
Jan 01, 2008 | Televison & Video
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
