Question about Apple iPod touch
No power,my i pod stops works and there is no power even when i try recharge!!!!
  • 255 Answers
If you try to recharge and there is no screen response, even a "recharging battery", you'll have to send it in to get it serviced.
Posted on Nov 25, 2009
SOURCE:
My I pod stopped working
How old is the battery ipod batteries can only be recharged a certain ammount of times before they need replacing
If an iPod appears not to turn on, check the hold switch on the device.
If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
If that is determined not to be the problem, the battery's charge should be checked. When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds.
If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
If no battery icon appears when trying to turn on the device, try resetting the iPod.
Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset procedure tried again.
hope this helps
Aug 19, 2012 | Apple MA146LL/A 5th Gen Video iPod 30GB -...
Hang-up
Hi, when a apple i pod freezes and refuse to function, it means that the i pod memory has stop working due to an application you installed in the i pod.
To rectify this problem, you will need to flash the i pod for the memory to start working properly.
Flashing an i pod helps you restore lost memory. After flashing the i pod, you can now start using it again as normal.
Take care.
Apr 14, 2010 | Apple iPod nano 3rd Generation
Itouch is frozen on white screen & wont turn off
Try doing a hard reset: hold the hard buttons for 20 seconds.
Heres a video to see for example.
http://www.youtube.com/watch?v=BuBWoZ0-gNM
May 06, 2009 | Apple iPod MA446LL/A MP3 Player
No power on Canon SD750
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Jan 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Audio control pod
I have a similar issue too, but my problem is that the sub has green light, and my control pod has an 'off' light, but it won't turn on :(
Jun 16, 2008 | Creative Labs Gigaworks S750 Computer...
I pod wont turn on
i have put my ipod to be recharged but its taking too long and dosent seems to be charging
Apr 11, 2008 | Apple Mini IPod
Apple iPod touch Logo
42 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Will Mishler
Will Mishler
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
