Question about D-Link DE 805TP (DE-805TP)5x10 Mbps Networking Hub
DC power adapter
Hi there, I just lost during moving house the power adapter for the D-link DE-805TP hub and there is no voltage on the hub so I don't know how to power it up now again with some universal ps, thanks for advice, Z.
  • 102 Answers
The adapter for the DE-805TP supplies 9 volts dc at around .5 amps
Posted on Jan 13, 2008
    Novelist:
  • 139 Answers
Unfortunately D-Link no longer provides detailed specifications for this unit on their web site. It may be necessary to replace the hub with a low-cost 10/100 ethernet switch.
AC 110/220 V ± 10% ( 50/60 Hz )
Posted on Mar 26, 2008
I'm trying to determine which AC/DC adapter to use with this device. Apparently the VDC should be 5-9V, is there a minimum/maximum current that you are aware of?
500ma (1/2 amp) should be fine.. It's imaterial if amp rating on power supply is higher, as the device will only use what it needs. A higher amp supply will simply run cooler as it not being demanded to run at capacity.
Dec 03, 2010 | D-Link DE 805TP/C (DE-805TP/C) Networking...
I can't 'find' my network printer when it is connected through the D-Link hub, but it is visible when connected direct to the router. The light on the hub flickers constantly when I plug the printer in to...
A "router" supplies an IP-address to a connected device, such as a printer, but a "hub" does not supply IP-addresses.
So, connect your printer to your router, and then access "Control Panel" and then "Printers" and then "Add Printer", and choose "add networked printer".
Jan 04, 2010 | D-Link DE 805TP (DE-805TP)5x10 Mbps...
Lost Power Adapter for Unicom Mini-switch/8 8 port
method 1: buy a power adapter that has a switch controlled output voltage - they usually have 3V - 4.5V - 6V - 7.5V - 9V and 12V selectable output. Start with 6V and if its not working unplug, select 9 and try again etc. etc.
method 2: open the case and locate an electrolytic capacitor right near the power plug - the biggest one. Note the voltage (for example it may say: 1000uF/15V) and have in mind that your device MUST work at a LOWER level that this.
you can combine the two methods to be safe...
Oct 02, 2009 | Port Incorporated 8-port 100Base-TX Mini...
Sony Trinitron KV-27EXR25
Just this week I had the same problem. If you are hearing a click responding to your pushing on the power button then it is more than likely a short that is preventing the problem. In my case it was a matter of dust.
I fixed the problem by opening up the back of the set and blowing all the dust out. There was a ton of dust accumulated on the circuit boards over the years. Once the dust was cleared I check to make sure the power fuse was not blown and it was fine. I then closed it up and it turned on without a problem.
My Sony is over fifteen years old and it still works like a charm. Its not HDTV, but it works great. When it finally goes; then I will buy a much bigger flat screen HDTV.
Good luck.
Jul 21, 2008 | D-Link DE 805TP (DE-805TP)5x10 Mbps...
Connecting 2 PCs Via the D-Link Hub
Hi Ajog,
Those Ips look good. Make sure the Subnet on both is 255.255.255.0. Since they are both getting to the internet, I assume the Gateway IP is correct.
On the 192.168.1.3, got to Start>Run and type in CMD. A black window will open, and type in PING 192.168.1.65. You should get four responses. If you don't, you probley have a firewall issue.
Do that same on the 192.168.1.65 machine, back to the 192.168.1.3 machine.
On the XP machine, follow these instruction, just skip down to Step 9.
http://www.geekgirls.com/windowsxp_home_network.htm
Vista gets a little tricker, but not bad. To setup the network on the Vista machine, go here, ad click on the Network icon.
Great link to save to your desktop!
http://windowshelp.microsoft.com/Windows/en-US/default.mspx
Using the network wizards should setup your firewalls to allow File and Printer Sharing.
Good luck
Jan 08, 2008 | D-Link DE 805TP/C (DE-805TP/C) Networking...
7 port usb hub
5V DC 3.7A  center + Adapter : )      Jay........
Dec 30, 2007 | Entrega (HUB-7U) Networking Hub
Connecting with dsl, and xbox, steps`
please give an username and password as you have registered in the isp if you are system admin then you can disable that username and password if not then tou have to contact your system admin for the clarification...
thank you...
Dec 14, 2007 | D-Link DE 805TP (DE-805TP)5x10 Mbps...
D-Link DE 805TP (DE-805TP)5x10 Mbps Networking Hub Logo
795 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
