Question about Zenith Televison & Video
I need codes for my remote to programm into other components
I need the code to program my yamaha soundsound to this remote
Posted on Jan 19, 2008
Flatron model. How do I use a Dixom remote to control?
Try a Harmony remote control. It will control several other components as well. It will never become obsolete or not work on a tv because of a code problem. The remote control is set up ONLINE, has every code imaginable for a huge amount of other components as well as most all TV's ever manufactured. They may seem a bit pricey at first, but will never become obsolete. If ever you change TV's or any other component in the future, you simply go back online to reprogram the remote to operate the new component.
Jun 05, 2015 | LG Televison & Video
I really need the urc8820. Remote code for a genesis 506
If your remote is programmable, it probably has a code search feature you can use to find a suitable code. If you search through all codes stored in the remote without success, you may have to try another programmable remote. Different programmable remotes have different code libraries.
Mar 02, 2015 | Televison & Video
I need the code for PLUSTRON URC11C-8A. I want to programme my Sony mini hi - fi component model MHC W550.
You have this backwards. The codes are stored in the remote. What you are seeking is a PLUSTRON code that will control your Sony device. If the remote has "code search" capability, you can use it to find a suitable code. If no code is found, your remote may not have one in its library.
Jul 25, 2014 | Audio Players & Recorders
How to program tv using this jensen universal controller
Hello
Proceedings to programme Jensen remote with TV follows.
[1] Manualy turn on the device you want to programme.
[2] Find three digit code for that device which you want to programme.
[3] Hold the device key down until the green indicator linght come ON.
[4] Release the device key. Within 30 seconds enter the three digit code number of your device.The light will flash when the right code has been entered.
[5] Press the Power Key. If the component turns off, you have entered the right code.
OK.
Apr 17, 2011 | Jensen 143307 Remote Control
Crk76vbl1 remote manual codes. I need codes
You haven't specified which devices you need codes for, so I've provided a link where you view/download your manual containing all the codes and the programming instructions:
http://help.mtaonline.net/dtv/remotes/rca/images/Remote%20Codes.pdf
The manual will open in a new browser window. You can then print it - or save it to your desktop/documents folder for future reference by clicking on "File" in the top left corner of the browser window and choosing "Save As..." from the resulting drop-down menu. If you are unable to see the manual after clicking on the above link you may also need to download Adobe Reader:
http://get.adobe.com/reader/
Here is also a summary of the programming instructions for your remote:
Direct Entry
1. Turn on the component to be programmed.
2. Look up the brand and code number(s) for the component on the code list in this section.
3. Point the remote at the component.
4. Press and hold the component button you want to program on the remote.
5. Enter the 4-digit code from the remote control code list on the following pages. If the indicator flashes, you have either entered an invalid code or the button isn't programmable. For example, if your remote came with your DVD player, you cannot program the DVD button to control another DVD player.
6. Release the component button, and then press ON-OFF to see if the component responds to the command. If it doesn't, try pressing the component button and then ON-OFF again.
If you get no response, repeat these steps using the next code listed for your brand,
until the component responds to the remote commands.
If you try all the codes for your component brand and none work, try the automatic
code search method. If automatic code search doesn
't find the code, the remote is not
compatible with your component.
Hope this helps.
Regards,
BElectric
Nov 21, 2010 | Televison & Video
I need the codes for ge universal remote controller model #J021
You can programme your remote by below method
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thank You
Sep 19, 2010 | GE RM24930 Remote Control
I need the codes for a magnavox
Manual code entry
Auto configuration
Thank You
Sep 19, 2010 | Universal Remote Control GE174Universal...
Need code for an old zenith t v. have remote but no codes to set remote
Manual code entry
Auto configuration
Thank You
Sep 18, 2010 | GE JASRM24912 Remote Control
Have a sony universal remote model RM-V401 trying to set code for a phillips tv
Procedure to programme Sony universal remote RM-V401 to philips TV are
2. On the remote control, press the SET button.
3. Press the appropriate component button for the component being set up.
4. Using the number pad, enter the component's manufacturer code.
5. Press the ENT button.
6. Point the remote control at the component.
7. Press the POWER button to verify operation.
Code for philips TV are 011 043 056
Thanx
Aug 06, 2010 | Philips Televison & Video
Need the code to work universal remote with airconditioner
usually there is a way to scroll through the remote to find your component. check through your manual to see what sequance you have to use
Feb 19, 2009 | Honeywell Programmable Thermostat Heater
Televison & Video Logo
37 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
