Question about Acer Aspire 3690-2196 Notebook
Removing thekaypad hi, i need to remove the kaypad to clean the popmy son spiled on it, the kays stick and hard to push down
  • 45 Answers
Try loosing the screw the connects the keyboard to the machine using a screw driver.
You can locate that at the back of the laptop.
with the help of a flat screw driver and a little force, you should be able to remove it..
Please try and get back to me and let me know the results..
Good luck
Posted on Jan 14, 2008
My hp mini is typing rapidly same letters and the some key are not working
You need to clean out the keyboard, it sounds as if something was spileed and causing keys to stick.
Dec 04, 2012 | HP 2133-1 Mini-Note PC
Non system disc or disc error fix
Hi, do you have a floppy disk, cd or usb stick inserted in your computer? Try removing such items and reboot as it may be trying to read these before the hard drive.
Check the boot order, when you first turn on your computer, access the BIOS menu (may need to push Delete, or one of the function keys eg F2, F8, F12 etc).
Check the boot order to ensure the correct hard drive it listed. Try moving the hard drive to the first option and reboot.
If removing any cd, usb stick etc doesn't help, try removing the hard drive and see if you can access it from another computer. If you can't access it, your operating system nay be corrupt and you may need to reformat.
Jul 28, 2011 | Intel Motherboard
How to install ram
Please shut the pc and;
remove all cables.
Open the case and locate the RAM slots on your motherboard. If u are still finding difficulties refer to your manual.
Thanks
May 31, 2011 | HP Compaq Presario SR1502HM PC Desktop
I am trying to reinstall windows xp prof but i keep getting the blue screen and the system keeps shutting down, i have tried a different hard drive but get the same error.
unplug all devices except the hard drive and 1 cd/dvd rom drive. disable the audio device and any other unnecessary devices within the BIOS and remove all pci cards. remove all but 1 ram stick, and try using different ram sticks, one at a time, while trying to boot. if it boots, with 1 ram stick, 1 hard drive and 1 dvd/cd drive then try adding/reenabling the other devices one at a time, until you find the device that keeps it from booting.
if your pc wont load with just a hard drive, cd rom and 1 stick of ram, then it is prolly trashed. if removing/disabling one of the other devices (such as the sound card or the modem card) allows it to boot, then you have found what needs replaced.
Nov 06, 2010 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
It keeps saying on the lcd memory stick error!
remove the memory stick, you should be able to see the backend of the stick, push it in and it will pop out. after removing the stick try operating the camera again.
Oct 27, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Suzuki VL intruder 125 back brake sticking and braklight stuck on
i too had this problem .....dnt worry just remove the brake cable and lubricate it with some spray like ABRO or WD40 lubricating spray then you sprayed some in the cable.play with it pull it forward and push it backward.,lubricate and repeat the steps till you find the cable goes smoother...you know it usually happens due to dust and dirt which enters the cable n get it stuck,try this n tell me..
Mar 26, 2009 | 2003 Suzuki VL 125 Intruder LC
My acer laptop keys are sticking and to hard to push down. I need to replace them how do I do that?
no they don't need replacing they just need cleaning, you can remove the panel that goes accross the top of the keyboard (above the F keys) if you remove this panel you can remove the keyboard too, it is connect to the laptop with a ribbon cable that you can remove. when the keyboard is free all you have to do is run it under warm water (not hot) and clean the keys gently with washing up liqiud that you use for the dishes, keep on running warm water on it until the keys are free (you may have to repeat this process if the sticking persists) Now for the important part, you have to leave the keyboard to dry for at least 24-48 hours in a warm dry room before you can put it back in, press on the keys periodically to make sure they are free
regards
Nov 23, 2008 | Acer Computers & Internet
Won't run
you have,nt seated the memory module back correctly.
push module in at an angle, usually about 45 degrees.
while pushing it back in, apply pressure, to push down towards the motherboard. ** check for any specs of Dust**
also check that you have,nt knocked the hard-drive ribbon cable in the process of cleaning.
Mike @ Compurepair.
Feb 23, 2008 | Toshiba Satellite A85-S107 Notebook
How to remove case from acer aspire 9300
Hi, your best bet is to remove the keyboard first, you will find other screws underneath which hold in the bottom section.
Have a good new year
John
Dec 29, 2007 | Compaq Presario M2000 Notebook
Acer Aspire 3690-2196 Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
