Question about Maytag MGC5430 Gas Cooktop
Heat too hot on LO simmer burner
Is there any way to reduce the heat on the SIMMER BURNER?? Even when set to LO , the heat produced is way too hot and can't get a true simmer (have tried different pots and still boils too hard). Our cooktop was installed and converted for use with LP Gas by the Maytag installer. If it is possible to adjust the heat produced - is it a do-it-yourself job, or does it require a gas professional?
  • Poppag Jan 22, 2008
    Thanks for helping me solve the problem. I can finally "simmer" on the Simmer Burner!
  • 4 Answers
Take the knob off, and take a very small flat screw driver, and inside the valve, turn it to the left, go slow, and you'll see that it goes down, there ya go
Posted on Jan 20, 2008
How can I adjust the flame on the simmer burner to be lower? It seems to be too much flame for a simmer. Otherwise cook top is working great.
Where the gas comes into the stove, there is a regulator. Have a service person check the incomeing gas pressure after the regulator with a manometer. Sounds like you are getting too much gas pressure to the range.
May 23, 2011 | Kenmore 30 in. 33202 / 33204 / 33209 Gas...
Electronic igniters will not turn off when the gas burner lites. all four igniters run untill you turn off the nob or unplug the unit
I'm dealing with this same problem. This cooktop has a dedicated simmer burner which is the only thing going on the lowest setting. This simmer burner seems to be how the igniter senses that it can stop. If it doesn't light, the igniter keeps clicking. Usually cleaning the burner will solve this. You may need to unscrew the nut holding the lower piece of the burner in place in order to clean it up.
Apr 17, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
Is 8000 btu.burner enough heat for general use
Hi, 8000 btu is a medium size burner, simmer burners are around 4000 btu, The largest are around 12000.
Feb 03, 2010 | Jenn-Air JGD8130 Gas Cooktop
I use one of the large burners most of the time and the minimum setting(simmer or ?) seems to have increased over last 4-5 years so that I have to turn burner off and let food cool, then turn on again,...
I am not sure of this Model but most of the Gas Rail Cocks ( Taps) when you remove the knob you will find either a small hole drilled into the spindle This would be the Low Burner (simmer Rate) Adjustment there would be a small screwdriver requiredto do this , if its not there ,then there is usually a small screw on the side of the tap under the Knob Hope this will help you
Jul 18, 2009 | GE 36 in. Profile JGP963 Stainless Steel...
Simmer is too hot
one way is the orfice that goes inside the burner.some have a little screwin the knob shaft to ajust.if no screw its the orficc.theres a tech sheet that will give you more detail about that on that stove.bottem drawer area or back.also so ranges have orfices on them in the back also.God bless,tom
Jan 01, 2009 | GE 36 in. Profile JGP962 Gas Cooktop
Extra low burner that won't ignite
Lowly what the potentior does is turn on the burner control system. When you turn on a normal burner you are opening a gas valve and closing a switch to generate a spark. Thus gas flow to the burner and spark. On the extra low simmer burner there is a electric solenoid between the burner head and the gas valve. this has to open as well for gas to flow. What the potentior does is signal the simmer control what level of flame you are requesting and telling the spark module to generate a spark. Once you go to the exlow setting the potentior tells the simmer control what level of heat and will cycle the flame on and off. So when the burner knob was between low and extra low, the flame would cycle on and off. You have to seperate the top section of the cooktop from the burner box to change the potentior for it sits on top of the gas valve for that burner.
Aug 10, 2008 | Thermador SGS36GS Gas Cooktop
Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
Burner doesn't simmer
Switch that controls that burner is bad and needs replacing
Nov 03, 2017 | Cooktops
Maytag MGC5430 Gas Cooktop Logo
456 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
