Question about Lexmark E320 Laser Printer
Copies come out smugged
When I print the copies are coming out with smugging on several part of the page. Does the fuser need replacement? If so, is it worth replacing? How difficult is it to replace?
  • 25 Answers
There are several things you want to check before you go replacing the fuser that usually just burns out and when it does all the panel lights flash at the same time. The problem you are describing is more likely excessive toner build-up check when the printer is off to see if there is a ridge of toner caked up where the paper enters the fuser assembly if so this can be scraped off carefully so as not to damage the fuser itself. Clean the transfer roller also or lastly clean the laser printhead itself it is able to be reached after removing the toner cartridge and using a DRY soft cloth to wipe back and forth along the fingerwide slit inside on the top of the printer. Also a defective/empty toner cartfidge could be to blame.
good luck
Posted on Jan 22, 2008
Why is my HP laser jet smugging the paper?
You may have a couple of bad cartridges, you may have a bad fuser unit. Were these oem or refurbished parts? Quality of refurbs can vary wildly. The heating elements on the 42xx series printers typically don't provide great performance when rebuilt.
Aug 11, 2014 | HP LaserJet Office Equipment & Supplies
TONER SMUG ON THE SIDES OF COPIES
Sounds like you are having a fusing pressure problem. I would call out a tech and get him to check out the Fixing unit area.
May 14, 2010 | Canon IMAGERUNNER 9070 Copier
could be a number of problems that would require a technician, you may need to call one in but as a temporary solution, if you are copying/printing A4 the try A4R or from portrait to landscape. this may help temporarily.
Mar 25, 2010 | Canon IMAGERUNNER 9070 Copier
PICTURE IS SMUGGED
If you're printing on photo paper, make sure you are printing on the correct side. Most photo paper has only one side to print on, the other side is a non-porous backing, and ink will sit on the surface until it dries (15 - 30 minutes, depending on temperature and humidity). And it won't look good even when it dries.
If you're printing on the correct side, try a different brand/type of photo paper.
Dec 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
What does it mean when there is a big smug down the middle of the received fax? Does it mean there is something wrong with the printing belt? Or that it needs a new ink cartridge?
does this happen with every recieved fax from every number... ? if so then the either the drum or fuser is bad... open unit and take a soft cloth and clean drum... look at the fuser see if you can match smudge to fuser or drum...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 09, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
Print issues
Look at the fuser, and see if you can see a bad area on the fuser roller, matching the position on the paper. I suspect a bad fuser. Fusers need to be replaced periodically, and typically via a maint kit which replaces several feed rollers as well.. How many pages have been printed.. Print a config sheet to display this information.
Nov 04, 2008 | HP LaserJet 3030 All-In-One Printer
Dell 3100cn printer trouble
this sounds like you might have 2 problems on you fuser is not getting hot enough to fully fuse the toner to the paper and two your black toner cartridge has been comprimised and needs to be replaced
Oct 16, 2008 | Dell 3100cn Laser Printer
Poor copies with OKI B4400
Possibly a fuser issue. Check by sending a 1 pg document to printer and opening cover when paper picked from tray but before it enters fuser. if image good then problem caused by fuser and you will need to replace. If image bad then possible defect with drum.
Oct 04, 2008 | OKI B4400 Laser Printer
Dirty printing
The cause of this is a faulty toner cartridge. What happened was some toner spilled out of the cartridge and down into your printer. Take the toner cartridge out and with a damp paper towel just goto town and wipe everything down.
Replace the toner cartridge, and in about 20 pages it should clear up.
Aug 18, 2008 | Samsung ML1740 Laser Printer
Canon d760
there are 2 possabilities for this
1 the drum unit is worn
2 the upper fuser roller/film has worn out
a visual check is needed to determine the cause
please get back to me if you require further assistance
Thank You
Jun 20, 2008 | Canon imageCLASS D761 Copier
Lexmark E320 Laser Printer Logo
125 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
