Question about Denon AVR-1100 Receiver
Says protect the receiver says protect and i want to know why
  • Anonymous Apr 01, 2008
    My friend have a Denon AVR-600 it turns on but the display says "PROTECT" and the standy LED flashes. What will I do to clear the protection mode? Is this unit still repairable? I badly need help...
    Please e-mail me at dondon_montallana@yahoo.com
    Thank you,
    Donald
  • Audio Service Clinic Sep 30, 2012
    Hello. My name is Dave. You have a damaged amplifier, and a condition known as DC Offset. Yes it is repairable by a qualified audio tech.Dave
  • 102 Answers
Probably some speaker wires got shorted or the output stages freaked out and the cpu went into protect mode. Normally plugging it out of and in to the wall socket should/could reset it.
First check all wiring at the speaker outputs and on the speakers
then if it still wont startup you could try the avr-1500 method with
some trial and error pressing of buttons.
avr-1500 reset method:
Unplug the unit from the wall, hold down both video select and audio select at the same time, plug it back in. Keep holding both buttons for 2 secs, unit will reboot. As you have no audio select button on your avr-1100 you might try pressing video select and another key to see if this will reboot it.
Posted on Jan 13, 2008
Why does "Protect" appear on my receiver before going out?
The receiver will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. verify that none of the speaker wire connections are loose at the back of the receiver or at each speaker. And verify that none of the wires are making contact with each other.
if it is, then remove the speaker wires and connect them again properly. After disconnection g the speaker wires, unplug the receiver for 10 to 15 minutes. This will make the overload protection back to normal
Try this and let me know. I hope this would solve the issue
Thanks
Nov 10, 2011 | Audio Players & Recorders
"Protect" flashes on the receiver. Fixable? Weather related?
Thanks
Turns on then says protector than turns of
Your receiver is in protection mode that's why.
Regards.
Apr 20, 2011 | Accurian AVR-5048 Receiver
My receiver, a sony str-k840p, is in protect mode. how can i reset it?
Good luck.
Apr 13, 2011 | Audio Players & Recorders
When turned on it says protect. instructions says that its a speaker short but i've checked and its not...please help
Just as you already know, the receiver will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. verify that none of the speaker wire connections are loose at the back of the receiver or at each speaker. And verify that none of the wires are making contact with each other.
If it is, then remove the speaker wires and connect them again properly. After disconnection g the speaker wires, unplug the receiver for 10 to 15 minutes. This will make the overload protection back to normal
Thanks
Feb 17, 2011 | Audio Players & Recorders
My receiver sat for five years, now it states "Protect"
Ok protect means there was a problem on the circuit, I am not there to see but please check for any bad capcitors,rails,amps ect ect if you do not know how to check this your going to need to check it into a repair shop for a eval.
Thanks I hope this helps please do rate the solution with the 4 thumbs above.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Feb 13, 2010 | Onkyo TX-SR700 Receiver
HI there, my receiver display "PROTECT" flashing! why?
THE GOAL HEAR IS TO DETERMINE IF THE INSTALLATION IS CAUSING YOUR PROTECTION FAULT OR IS IT THE RECEIVER ITSELF HAVING INTERNAL DAMAGE. REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION, THEN THE RECEIVER WILL NEED TO BE SERVICED, AS YOU HAVE TOTALLY SIMULATED A BENCHED CONDITION THAT IS TOTALLY INDEPENDENT OF YOUR INSTALLATION. MOST TIMES, THE RECEIVE WILL GO INTO PROTECTION WHEN IT SEES AN EXCESSIVE LOAD WHEN TURNING UP THE VOLUME, WHICH IS USUALLY CAUSED BY TOO MANY SPEAKERS OR DAMAGED SPEAKERS, BUT IF NO SPEAKERS CONNECTED, THEN IT IS USUALLY BECAUSE THE RECEIVER SEE AN EXCESSIVE LOAD DUE TO ITS OUTPUT SECTION BEING DAMAGED. IN ANY CASE, ONCE REPAIRED, YOU MUST CHECK YOUR SPEAKERS FOR BURNED VOICE-COILS, WHICH WILL IMPOSE AN EXCESSIVE LOAD TO THE AMPLIFIER AND CAN CAUSE IT TO FAIL AGAIN. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 14, 2010 | Sony STR-DE598 Receiver
Sony STR-DE698 7.1
in Sony receivers Protect display shows problem / fault in Amplifier output area. Qualified technician can repair the damage.
Regards,
Sep 04, 2008 | Sony STR-DE698 Receiver
My receiver is in protect mode.
The units in the protect mode because the Microprocessor detects a large current being drawn by the amp. section of the reciver. This is a solid state unit and there are no user replaceable parts inside this unit. Unless you know how to trouble shoot sloid state devices then you should seek a pro to assist you with this repair. GOOD LUCK
Jun 25, 2006 | Sony STR-DE597 Receiver
Denon AVR-1100 Receiver Logo
300 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
